Supermono fuel hose
atomibart
PostPosted: Tue Apr 08, 2014 8:47 am    Post subject: Supermono fuel hose Reply with quote
Hi,
The BB1 owners will have noticed that the blue fuel hose is really (too) close to the engine block and to the exhaust...and it does not seem to appreciate this location.
Did anyone find a way to improve that ?
Thanks in advance for your feedbacks
atomibart
PostPosted: Tue Apr 08, 2014 2:02 pm    Post subject: Reply with quote
Drop BimotaNige a pm directly atomibart.......only guy I know on here that has a BB1 that he regularly runs and tweaks......running standard set up with tank down below in the belly pan..........You could heat wrap the pipe.....or simply replace it with one with a heat wrap casing already on it which would be best.instead of plain rubber use pipes with a textile web strengthening and outer core
