Wanted front forks - VDUE
PostPosted: Wed Apr 23, 2014 3:18 pm    Post subject: Wanted front forks - VDUE Reply with quote
Hi all
1 x pair of VDUE forks
1 x fork tube / force pipe , part number - 949310500
1 x compres adjust kit , part number - 849311530
New or second hand OK
Cheers Trev
PostPosted: Thu May 01, 2014 10:48 pm    Post subject: Reply with quote
Anyone done a upgrade and have them sitting around ?
Know of a place that sell the parts to fix mine ?
Trev
PostPosted: Fri May 02, 2014 8:05 am    Post subject: Reply with quote
Have you not tried Pierro Carroni in Italy? Although he only has one Full Vdue Trofeo left he does have lots of spares...........
PostPosted: Fri May 02, 2014 1:28 pm    Post subject: Reply with quote
Are the forks similar to the SB6 and 6R - obviously they'd have different cartrides and spring rates but 46mm RWU Paoili .... fork tubes might then be on ebay italy or germany.
Always get it wrong but Comp adjusters are on the ... bottom of the fork ? K-Tech do after market adjusters for most common bikes they might be able to help if you give details or send the originals to them ???
PostPosted: Sat May 03, 2014 4:06 am    Post subject: Reply with quote
Piero does not have any fork parts
I can get other forks there are lots around (off other models)
but I was hoping to fix the ones I have for spares
Trev
PostPosted: Sat May 03, 2014 10:24 am    Post subject: Reply with quote
Generally if you can't find spare for a Bimota you get them made. Find an engineering or suspension company that can machine what you need.
PostPosted: Tue May 20, 2014 11:14 pm    Post subject: Reply with quote
Got forks now
two pairs easy
Trev
