Corona
Posted: Sat May 24, 2014 11:56 pm Post subject: |
They won't fit the fuel injected model as the outside is recessed for the retainer to fit, this also affects the sprocket alignment. 750 Paso ones fit the ie models which is a bit of a headache, wemoto can get JTL sprockets in alloy or steel for the rear. |
Posted: Sun May 25, 2014 9:35 pm Post subject: |
So 750 Paso front sprockets have the 3mm recess in them ?
The db4 and the db2 have the same recess as the db4ie. |
elmisti
Posted: Fri Dec 20, 2019 6:39 pm Post subject: |
you find sprockets in germany at
https://www.wieres.com/Shop/1226-15
i bought this for my db 4 i.e. just a week ago and used another one before _________________ db4i.e. - Le Mans III - Gran Canyon - Desert X -Sportster |
