mainstone41
Posted: Wed Aug 06, 2014 3:41 am Post subject: |
_________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851
Posted: Wed Aug 06, 2014 3:43 am Post subject: |
Looks nice. Were you able to use the original cables or did you have to change them? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Wed Aug 06, 2014 9:38 am Post subject: FCR 39s |
Where are you on jets and needles? Any compromises on rideability? Did you leave the motor in the frame when you notched the bracing spar? I guess there's enough material left there for it not to have materially compromised the spar's strength. We're looking forward to the results of the dyno run _________________ What, Jonny's gone! |
Posted: Wed Aug 06, 2014 2:37 pm Post subject: |
Very nice ... interesting innit Jonny _________________ Don't read everything you believe |
Posted: Wed Aug 06, 2014 3:29 pm Post subject: FCR39's |
It surely is Chuckie _________________ What, Jonny's gone! |
mainstone41
Posted: Wed Aug 06, 2014 6:23 pm Post subject: |
brian wrote: |
Looks nice. Were you able to use the original cables or did you have to change them? |
I had to change them, just ordered a kit from Venhill cut them to length and soldered the ends on. |
mainstone41
Posted: Thu Aug 07, 2014 10:38 am Post subject: Re: FCR 39s |
Jonny B Bad wrote: |
Where are you on jets and needles? Any compromises on rideability? Did you leave the motor in the frame when you notched the bracing spar? I guess there's enough material left there for it not to have materially compromised the spar's strength. We're looking forward to the results of the dyno run |
At the minute i have no idea what the jets are set at, it is running rich but even like that its mental to ride. A dyno run won't be gettin done till later in the year after I've had some fun while the sun still shines. I notched the frame with the engine in and removed to smallest amount i could to keep the frames strength, also had to remove some material from the shock mount. |
Posted: Thu Aug 07, 2014 11:56 am Post subject: FCR 39's |
I was talking to a bloke who ran a dyno shop and built drag bikes a few years back and he said that he'd just dialled in a set of flatslides for a customer (can't remember what bike) and the bloke said it felt as if the thing had been turboed - so "a mental ride" sounds about right _________________ What, Jonny's gone! |
Posted: Mon Aug 18, 2014 8:05 pm Post subject: |
Nice job. That's a good idea to seal welding the holes.
Now I'm curious about the Dyno run. _________________ vince
mainstone41
Posted: Mon Aug 25, 2014 9:35 am Post subject: |
Will have to make a seat type thing up for the dyno run so they have some where to sit and also somewhere to strap it down to, as last time they managed to rub off some of the frames anodising!
Thought i'd mention that i fitted a GSXR600 SRAD fuel cock and it manages just fine with no fuel starvation problems at all. |
Posted: Mon Aug 25, 2014 5:00 pm Post subject: |
Is the fuel cock a straight swap and do you have pictures of that _________________ vince
Niels
Joined: 23 Mar 2013 Posts: 24 Location: Groningen, The Netherlands
Posted: Wed Aug 27, 2014 7:56 pm Post subject: |
Very Nice job mate! I'll bet you can sell these tank brackets here
I'm also trying to get my SB6 running right but ditching the airbox looks just the way to go at this moment. |
mainstone41
Posted: Sun Aug 31, 2014 9:36 am Post subject: |
Vince186 wrote: |
Is the fuel cock a straight swap and do you have pictures of that |
The fuel cock is a almost a straight swop, had to file flat the bottom of the tank flat so the suzuki tap would seal correctly and its only a single outlet so got a t piece connector. |
mainstone41
Posted: Sun Aug 31, 2014 9:40 am Post subject: |
Niels wrote: |
Yeah lose the airbox far better.
The bracket was my design but had help from a friend to produce the many tries to get rite! |
