cwhotto
Posted: Mon Jul 21, 2014 1:06 pm Post subject: idle speed |
Has any one had problems with tick over i have YB11 and will run fine over 2500 rpm but below is lumpy could this be the exup exhaust valve or carbs.
Chris _________________ Bimoto yb11 |
Posted: Mon Jul 21, 2014 2:08 pm Post subject: |
Hi Chris
More likely to be a blocked carb pilot jet or 2 - does it run better with the choke slightly on at those low revs? Presume its lumpy when youv'e warmed it up? Its not likely to be the exup valve - you can see the cables turning it to check that. To be honest when I'm riding I don't use such low revs as it is snatchy and harsh - its not the smoothest engine! _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
