SB4/5 (HB2/3 KB3)
Frank.61
PostPosted: Mon Sep 22, 2014 3:56 pm    Post subject: SB4/5 (HB2/3 KB3) Reply with quote
Hi,
Who has a SB4 (or SB5, HB2/3 or KB3) with a rear shock with a separate hose connected compression tank/container?
I wanted to know if you have experienced mounting problems with either hose or tank/container?
I want to order such a rear shock but the supplier says it's better to use a more conventional shock without a tank/reservoir ......
The only reason I want it is since I want to be able to adjust the compression damping if necessary.
I assumed mounting a rear shock with the extra hose and tank/reservoir would be a simple job....
Could it be I oversee something??? Confused
Maybe a picture would tell a thousand words! Very Happy
Frank
