New DB4 owner checking in
V10LEE
PostPosted: Sun Nov 09, 2014 11:04 pm    Post subject: Reply with quote
Hey guys thanks. Yeah with these older European bikes you never know lol. I'll just leave it . With that said i am a two stroke guy and I'm impressed how light this bike is and the handling..
PostPosted: Sun Nov 09, 2014 11:11 pm    Post subject: Reply with quote
In what way do you think the speedo is not reading right? Running faster or slower than you think youre going? As I said...it is a mechanical unit running off the front wheel..........is your clock in Kms (euro spec) or miles per hour? If its a euro clock in Kms/p/h check to see if someone has put a mechanical converter on it under the clocks...an additonal converter added to the cable so that the kms are now to be read as miles....?
V10LEE
PostPosted: Sun Nov 09, 2014 11:18 pm    Post subject: Reply with quote
Hi 2bims the speedo is in mph. When I punch the throttle and go fast. The needle does not move past 40mph.
V10LEE
PostPosted: Sun Nov 09, 2014 11:20 pm    Post subject: Reply with quote
Maybe the bike just needs to be ridden more, and it will clear up. Who knows.
PostPosted: Mon Nov 10, 2014 12:22 am    Post subject: Reply with quote
Sounds odd that one....the inner speedo cable is round...whilst the parts that push into the speedo and the speedo drive on the front hub are squared off to fit. Usually when the cable snaps its a short piece that may break off one of the ends....fine at low speeds...but loses "bite" at higher speeds. Unscrew at the speedo drive section on the front wheel and check the cable turns properly by hand and is not rusted up...or with any broken ends......I'd suggest first you change the entire inner and outer cable with one from a Ducati 900SS or 900ssie, Ducati 748/916.Ducati 750ss etc etc ....If you can unscrew the entire assembly and take it to a ducati dealer they usually have stock of these items...make sure you get one with the same ends and of the same length overall...or a bit longer...but not shorter....I fitted a shorter one once and on accelerating up a ling hill the forks extended out to full strtch and it pulled the crimped end off at the speedo drive end as it stretched it too much.....a new one should only be around $15...so worth it to try....I wouldnt think that this would get "better" with running......the clock themelves are relaible enough and I've never had problems with those...only ever the cable or outer sheath itself.........
V10LEE
PostPosted: Mon Nov 10, 2014 1:01 am    Post subject: Reply with quote
2bims thank you very much I will try that. It seems like a simple fix. Man I really love this bike!
deebee4
PostPosted: Sat Nov 22, 2014 2:41 pm    Post subject: Reply with quote
My speedo stopped going over 210 km/h even when I was still increasing in speed (no clutch slipping Wink )
Funny Italian clocks.... Now I only have the rev counter (working fine), small switch panel and a lap timer.
The day I highsided...
Same turn, but new colour scheme after repair. Unfortunately the colour red is not so bright on the pictures...
PostPosted: Sat Nov 22, 2014 11:14 pm    Post subject: Reply with quote
New helmet and new number too Wink
The bike's looking fantastic deebee
V10LEE
PostPosted: Sun Nov 23, 2014 12:11 am    Post subject: Reply with quote
Hey guys so I found a brand new whole guage cluster on Ebay for my DB4. Same as a 2000 Ducati Supersport. Anyhow I'm going to swap out the whole unit. I think this should fix my problems instead of trying to tinker with the existing unit..
deebee4
PostPosted: Sun Nov 23, 2014 12:28 am    Post subject: Reply with quote
Thanks, Brian. New helmet was necessary due to a blow on the head that caused a light brain concussion. Still not fun.....was a bit groggy when I crawled up. I've seen the footage from the closed video system of the track. Classic highsider. But the helmet saved my life, did its job, so I'm happy.
The number: I don't have a fixed number anymore because I let my racing license expire 2 years ago. I'm not doing real races anymore, due to a neck hernia that caught me out in the end of 2008. I'm happy enough to be able to ride on track and on a sports bike anyway. In fact it's better for me to ride on track compared to road riding. Road riding is more static and on long rides it stiffens up the muscles in my neck and shoulders.
Getting the bike and my body in shape for the 2015 season..... Smile
I presume that you havent checked out the Speedo drive cable as yet then Lee?
i'll keep my fingers crossed for you that it sorts both problems out....but I have my reservations..........Speedo issue is 90% going to be the cable or the drive on the wheel...but could be the nylon cogs inside the speedo itself...so hopefully a new speedo can sort this as the clocks arent intended to be taken apart...unlike on earlier DB2 or carbie 900ss...where the drive unit on the back of the speedo can be removed, cleaned and checked
As for the tacho....hopefully sorted also.....but I still reckon its a break in the very flimsy Ducati sourced wiring that leads to the tacho.......when I swopped my tacho for a 900SSie one it still didnt work...and cut out the rear cylinder to boot also...so I put the old one back in and rear cylinder came back to life...just made do without a working tacho.......
deebee4
PostPosted: Sun Nov 23, 2014 12:29 am    Post subject: Reply with quote
If the price is right just do it. It should be a direct swap. Smile
V10LEE
PostPosted: Mon Nov 24, 2014 1:03 am    Post subject: Reply with quote
Nice pics deebee! I like your setup. I do a lot of track days with my Vipers,and do karting as well. I haven't done a track day on a motorcycle yet. I say yet,but will probably stick with 4 wheels.. Ha Laughing
deebee4
PostPosted: Mon Nov 24, 2014 9:04 am    Post subject: Reply with quote
Thanks. Well, could well be that after your first track day on 2 wheels you're addicted. Just the sheer manoeuvrability and physical input: moving from one side of the bike to the other, hanging off, dragging your knee, tucking away behind the screen, staying on the bike when braking hard, looking through the turns, delicately twisting the throttle mid corner and really opening it up as soon as possible to get the maximum drive out of the turn etcetera. With full respect to the 4 wheel drivers: this can't be beaten.... Wink
V10LEE
PostPosted: Mon Nov 24, 2014 8:22 pm    Post subject: Reply with quote
Yeah that sounds like a blast. I use to love watching Wayne Rainey, Kevin Schwantz, Eddie Lawson battle it out at Laguna Seca Raceway. Man those were the days.
Some 4 wheel action.. My 2010 Viper ACR
Page 3 of 4
