EYREY1
Posted: Fri Nov 28, 2014 1:31 am Post subject: 39mm keihin pwk's |
im building a v due motor to put in a special and needed some carbs and a set of next to new pwk 39mm carbs came up at just under 200 quid so i bought them ,
has anyone used them or know of a reason why i should sell them and get some dellortoes that std v dues run ?
i would just rather do it now if i have to ?
thanks Gary |
SethG
Posted: Fri Nov 28, 2014 5:43 am Post subject: |
Are you going to run premix? Or use the existing oil pump? |
EYREY1
Posted: Fri Nov 28, 2014 4:32 pm Post subject: |
pump i think its a must do
ive seen the oilways that go down the crankshafts
i suppose they feed the bearings so would like to use them
and there are 2 more 1 either side of the conrods that look like an after thought , is thatt the mod that pirero talks about ?
the bottom end has been modify'd by team tutapista who raced it in the trofero race series , or at least the previous owner said it had . |
SethG
Posted: Fri Nov 28, 2014 7:12 pm Post subject: |
Haha, no I mean the oil feed to the carbs. |
EYREY1
Posted: Fri Nov 28, 2014 9:02 pm Post subject: |
if thats what the dellortoe carbs use then yes |
