DB4ie Dyno numbers
polyesterpig
PostPosted: Sat Nov 29, 2014 9:24 am    Post subject: DB4ie Dyno numbers Reply with quote
My bike has been down for a couple of years due to a valve guide going out and no spare time to sort it. Well Finally got my motor together and put it on a power commander Dyno. I wanted to see where I am at. It is a Bimota DB4ie, which I thought it had a Ducati 900ssie motor, but it has the Monster 900ie injectors and the 900ssie coils?
The motor had the heads ported, a Giannelli slip on exhaust, and the throttle body butterflies knife edged with the shafts milled flat. I also put on a Ducati performance 900ssie ecu knowing it was the closest choice. (currently no power commander installed)
I know every Dyno varies, so here are the results:
Max power 83.60 @ approx 8000rpm then slowly drops off.
Max torque 59.96 @ approx 6200rpm then slowly drops off.
I don't know if I was expecting more, since I didn't know what the stock numbers were?
The curve is pretty smooth for both hp & torque but it dips around 2500 rpm. It seems to be a running a little rich per the AFR graph in that area. I don't know if it needs a power commander map added? I think I will just ride it for a while and see what happens.
If I can figure out how to post the results, I will.
2002 Cannondale E440
(3) 2003 Cannondale E440R
2000 Bimota DB4ie BiPosto
V10LEE
PostPosted: Sat Nov 29, 2014 9:40 am    Post subject: Reply with quote
Very nice. What part of Cali you in?
polyesterpig
PostPosted: Sat Nov 29, 2014 11:37 am    Post subject: Reply with quote
So Cal
deebee4
PostPosted: Sat Nov 29, 2014 1:01 pm    Post subject: Reply with quote
Hmm, your max torque value seems quite low for a somewhat tuned fuel injected 904cc Ducati engine.
My carbed db4 (944cc kit etc) showed 96,2 Nm (71 lbft) @ 5.608 rpm on the dyno in March this year.
Seems like there's room for improvement in the fuel/air ratio in mid range.
On the dyno graphs you can see how crudely a carburettor regulates the fuel/air mixture. Altering a main jet influences more than just the top end. And needle positions too. So it's always a compromise, no perfection possible on carbed engines. You guys with the fi bikes are lucky to be able to regulate the mixture at any rpm.
Still, I like to hold on to the carbs, even if it was just for the flapping sound of the flat slides Laughing
polyesterpig
PostPosted: Sat Nov 29, 2014 5:59 pm    Post subject: Reply with quote
I think the low torque figures are due to stock compression Pistons. Looks like you have a 944 piston kit installed. If it is a high compression piston kit, that would bump the torque up.
deebee4
PostPosted: Sat Nov 29, 2014 6:25 pm    Post subject: Reply with quote
Yes, it's the high compression Pistal Racing kit. But still, I remember having better torque values with the stock barrels/pistons years ago. I'll have to dig up the printed graphs in my archive...
macchiman
PostPosted: Mon Dec 01, 2014 10:32 pm    Post subject: Reply with quote
I had my DB4ie dyno'd a few years back, also on a Dynojet. Standard engine with a modified map. Max power was 77.3 @ 8000rpm, max torque 55.7 ft-lbs @ 6000-6250 rpm.
Bimota DB4ie
Ducati Paso 750
Aermacchi Ala Rossa 250
Parilla Wildcat 250
Neracar 1922 221
Corona
PostPosted: Tue Dec 02, 2014 8:47 pm    Post subject: Reply with quote
Bog standard with no tweaking
Compression was lower on the front cylinder but not by much
polyesterpig
PostPosted: Tue Dec 02, 2014 9:55 pm    Post subject: Reply with quote
http://www.ducati.ms/forums/attachments/supersport/476770d1417462651-dyno-results-900ie-db4ie-dyno-.pdf
http://www.ducati.ms/forums/attachments/supersport/477010d1417534784-dyno-results-900ie-bimota-dyno-run2.pdf
Corona
PostPosted: Thu Dec 04, 2014 9:40 pm    Post subject: Reply with quote
That's close enough for me PP, a shot of chain lube or dyno calibration difference seems the only minor difference. The quest for more power on these engines always seems like your robbing peter to pay paul, I wouldn't want to sacrifice the driveabillity of the bike for a few hp more at the top unless I was track riding.
