gearbox oil in rotor housing ?
EYREY1
PostPosted: Fri Mar 06, 2015 4:16 am    Post subject: gearbox oil in rotor housing ? Reply with quote
i looked at a few you tube vids of v-due bikes
there is one on a dyno and you can see the rotor it must have a clear cover on and everytime the revs built up the rotor housing fills with gear box oil .
so i looked at mine and there is a big hole from gearbox streight into the back of the roter ? why ?
and there is a gap between the rotor housing where it connects to the generator /flywheel housing ?
is it right they fill up with oil ?
its just ive not seen this on any other bikes ,why are they like that
how can pickups work in the oil ?
why would you want oil in your generator ?
it sort of answers the question i posted about the vents on the covers .
can anyone explain please i feel a bit retarded thinking about this .
thanks in advance Gary
Weed
PostPosted: Fri Mar 06, 2015 9:35 pm    Post subject: Reply with quote
You will find that most if not all alternators on motorcycles are in oil. There is a bearing behind the alternator that likes a bit of a sip of oil now and again. The sensors be it magnetic or hall effect work fine in an oil atmosphere as well. Any motor with EFI have these sensors
PostPosted: Fri Mar 06, 2015 11:27 pm    Post subject: Reply with quote
and don't forget Bimota said no one's done this before so lets do it
maybe it will work too ?
Trev
EYREY1
PostPosted: Sat Mar 07, 2015 12:09 am    Post subject: Reply with quote
thanks for the reply guys !
i was just about to start mixing the jb weld up !
crisis averted ! oil is good .
