sbbimota
Joined: 24 Oct 2013 Posts: 63 Location: santa barbara
Posted: Fri May 15, 2015 3:48 am Post subject: bulb replacement behind speedo and tach |
could use an assist on replacing the bulbs that are burnt out. i see the little plastic caps on the back of the cluster, and i can see a what looks like a phillips head screw (but doesn't fit a phillips head screwdriver) but not sure how to get at the bulbs. didn't want to attempt an unscrew in case that was the wrong approach.
assist please.
thanks. _________________ pete |
Posted: Fri May 15, 2015 10:12 pm Post subject: |
Mk1 or Mk2 ?
Mk2 you need to take the clocks off ... its probably the same with the Mk1 _________________ Don't read everything you believe |
sbbimota
Posted: Sun May 17, 2015 12:17 am Post subject: |
Um ... is this a Mk1 with the Suzuki clocks ? I haven't seen anything like that before _________________ Don't read everything you believe |
Posted: Sun May 17, 2015 12:18 am Post subject: |
Might need a pic _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
sbbimota
sbbimota
Posted: Sun May 17, 2015 1:46 am Post subject: |
Posted: Sun May 17, 2015 8:40 am Post subject: |
Which bike is this - I thought it was a SB6 _________________ Don't read everything you believe |
sbbimota
Posted: Sun May 17, 2015 3:36 pm Post subject: |
SB6R....looks exactly the same as the owners manual _________________ pete |
Posted: Sun May 17, 2015 5:17 pm Post subject: SB6R clock bulbs |
Use a large flat blade screwdriver to turn the cap a quarter of a turn and then the bulb will drop out. The bad news is that the bulb and holder look to be one piece, so you probably won't be sourcing new ones from your local spares shop.
Good luck. _________________ What, Jonny's gone! |
sbbimota
Posted: Tue May 19, 2015 3:55 pm Post subject: |
ok...i can rotate the screw as you mentioned, but how the hell is one to get it out? the access hole is about the same size as the bulb assembly. if i turn it upside down I am afraid it will end up in the back of the clock and i'll never get it out....i can't believe Bimota would be this stupid to not allow access to change a bulb, but then again you have to drop the engine to change a sprocket. _________________ pete |
Posted: Tue May 19, 2015 6:02 pm Post subject: SB6R clocks |
To be fair, these clocks will not have been made by Bimota and with limited production there wouldn't have been much scope to get them improved. Once you've turned the cap a quarter turn, just turn the clocks upside down and the bulb will drop out, or not, as you've correctly deduced But, as I say, I wouldn't bank on finding any new ones. Perhaps try Bimota Classics. Failing that, chuck the clocks in the bin and put a decent set on. But, be warned, you haven't got a lot of loom to play with. _________________ What, Jonny's gone! |
Posted: Tue May 19, 2015 6:32 pm Post subject: |
Always they moan about the sprocket !!!!
All design is compromise. _________________ Don't read everything you believe |
Posted: Tue May 19, 2015 8:43 pm Post subject: SB6R clocks |
Newbies eh Chuckie!
Sprocket hasn't even made my Top 10 for years _________________ What, Jonny's gone! |
bimotacarbon
