bulb replacement behind speedo and tach
Goto page Previous  1, 2
PostPosted: Wed May 20, 2015 10:26 am    Post subject: SB6R clocks Reply with quote
Ah!!!! Wrong again - story of my entire life.
However, with one last roll of the dice, I would suggest that €26 for one bulb delivered, is significantly more than the entire clock-set is worth Laughing
Pipe up Oily. I believe you have experience here.
sbbimota
PostPosted: Sun Jul 05, 2015 12:42 am    Post subject: hands and bulbs Reply with quote
so gents...got the clock apart and am able to access the bayonet style bulb...still no luck finding them....any help would be appreciated...if not, I'm going to wire in LED's....but to do that I need to remove the clocks from the circuit board...I know getting the clock hands is a special procedure...any assist would be appreciated.
pete
pete
PostPosted: Sun Jul 05, 2015 8:17 am    Post subject: Reply with quote
Can you post a pic of the bulb?
PostPosted: Sun Jul 05, 2015 10:06 am    Post subject: Reply with quote
As Brian says, some pictures can help. For me it is not clear which clock you mean.
vince
PostPosted: Sun Jul 05, 2015 12:58 pm    Post subject: Reply with quote
I think there was one bulb that was really small, I found it in a car parts place.
sbbimota
PostPosted: Tue Jul 07, 2015 7:22 pm    Post subject: Reply with quote
pete
PostPosted: Tue Jul 07, 2015 10:02 pm    Post subject: Reply with quote
Doesn't it come out of the bulb holder ?
sbbimota
PostPosted: Thu Jul 09, 2015 7:47 pm    Post subject: Reply with quote
it can be removed, but no identifying marks on the bulb.
pete
PostPosted: Fri Jul 10, 2015 12:02 am    Post subject: Reply with quote
When you pull the bulb out...does it look like these??
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xcapless+bulb.TRS0&_nkw=capless+bulb&_sacat=0
Called capless bulbs.........go to your wiring diagram in Owners handbook/workshop manual if you have one and it will tell you the wattage of the bulb...I'm guessing 12v 3 watts
Should be easy enough to buy....car accessory shops/garages
sbbimota
PostPosted: Mon Jul 13, 2015 4:52 am    Post subject: LED replacement found Reply with quote
Found the replacement for the bulb...see photo...found on a LED website...superbrightleds.com...bought the 4mm ones..just when you install don't twist all the way as they contact is just about 5 degrees further around then the standard ones...
this solves the problem..i can then reglue my clocks back together and never take apart again until they crap out..but at least i won't be changing any bulbs.
see ya
pete
Page 2 of 2
