Yb8e fairing mount
Jimip86
PostPosted: Thu Dec 17, 2015 9:01 pm    Post subject: Yb8e fairing mount Reply with quote
Hi could anybody help me regarding how the yb8
Fairing should mount towards the rear belly pan area.
This is the bracket I have , presume there should be a plate or something for ether side to screw to ??
PostPosted: Fri Dec 18, 2015 12:20 pm    Post subject: Reply with quote
Hi, I'll get a photo over the weekend to see what's fitted to mine.
Jimip86
PostPosted: Fri Dec 18, 2015 8:59 pm    Post subject: Reply with quote
Thanks , much appreciated
PostPosted: Fri Dec 18, 2015 9:12 pm    Post subject: Reply with quote
That bracket is quite clear on the Exploded spare parts diagram for the YB8e....theres supposed to be a rubber and a bush...part Nos 16 and 17 on here....be patient...the pages take a while to load up...when its loaded click on the picture and it will grow bigger and in more detail....the bolts and parts you should have are the same as holds the front nose part of the fairing underneath the headlights at the front...same part nos...
http://www.sfogliami.it/flip.asp?sc=z94th0c6o34vrd5jo4hxpygr2j3xtulg&ID=117649#page/34
and then a bolt that goes through them to the plate that has a threaded captive nut on it
as on here part Nos 23 and 22 that bolt through the bush and rubber into the triangular plate part No 9 as on here
http://www.sfogliami.it/flip.asp?sc=z94th0c6o34vrd5jo4hxpygr2j3xtulg&ID=117649#page/26
bimotabob
PostPosted: Fri Dec 18, 2015 9:28 pm    Post subject: Reply with quote
Thats the same part as on my YB8EI.
The cleaner at work threw mine out so had to make a copy out of stainless steel.
Simple triangular bracket with 1 nut welded for the fairing screw and a hole on the side for fitment to the steel bracket Bimota fitted that also has the stand mounted to it.
The fairing bush and spacer are able to be found or made similar but the originals would be excellent - if they were available.
Yours looks like you need to sandblast and paint/powder coat or make a new one.
YB8EI
PostPosted: Fri Dec 18, 2015 9:41 pm    Post subject: Reply with quote
Yeh I saw the rust and the flakey paint...but didnt like to mention it.........if I was round there it would have been taken off wire wheeled clean, primed and enamel spray painted black and shiney by now......... Laughing
Jimip86
PostPosted: Sat Dec 19, 2015 1:06 am    Post subject: Reply with quote
Don't you worry the flaky paint will be sorted in good time, just bigger things to sort first ,
PostPosted: Tue Dec 22, 2015 2:01 pm    Post subject: Reply with quote
Okay Dad, I'll hold the hammer, but don't implicate me in this mock idiocy?
PostPosted: Tue Dec 22, 2015 2:29 pm    Post subject: Reply with quote
Hi, did the diagram above sort your issue or would you like some photos still?
Jimip86
PostPosted: Tue Dec 22, 2015 2:36 pm    Post subject: Reply with quote
I'm still a bit confused , I get that it just bolts on to bracket but what joins ether half of the fairing together at the split ??
PostPosted: Tue Dec 22, 2015 3:36 pm    Post subject: Reply with quote
Presumably the lower fairing under the belly pan has a split on it....and the two "halves" so to speak overlap each other...thus the bolt pushes through holes on both halves....and its held tight with the clamping action of the bolt on the bracket...and up front at the lower there should be a dzus fitting that goes through both halves again to clamp them together........Its such a sound "clamping" that on the DB2 for instance which shares the same one piece clamshell type fairing.....theres 3 dzus fasteners underneath...but none go to an engine mount or other....they just clamp together and its rigid.....benefit of fibreglass moulding over flimsy plastic shells......
