Costiera DB7
Posted: Mon Jul 27, 2015 10:45 pm Post subject: DB7 dimensions |
Hello all... Does anybody have the width (bar to bar measurements) and the height from floor to bar end please? My bike, which I hopefully get hold of on Friday has to fit through a very small space to be safe at night. I'm thinking of cutting a notch in the door frame. My 899 Panigale gets through so thats the benchmark and I want to know in advance before the Bimota arrives whether it will fit or not.
Thanks in advance |
Posted: Tue Jul 28, 2015 1:16 am Post subject: |
Handlebars height is 860mm ..........wingmirrors can be folded up so no problem there...total width 700mm
These dimensions are from the sales brochures though...so best that someone with a Db7 does an actual measure prior to you cutting into your door frame.... |
djt77
Posted: Tue Jul 28, 2015 2:24 am Post subject: |
The bars can be moved if need be to get it in and out of storage, would be a pain if had to do it every day. Just checked mine and at its widest point its no more than 850mm a bit less maybe 20/30mm hard to get an accurate measurement. The end of the brake and clutch lever protrude out a little more than the bars.
I'd be very surprised if didn't fit through an opening that an 899 can't its a very slim bike.
Oh and congratulations and pics please once you have |
Costiera DB7
Posted: Tue Jul 28, 2015 3:27 pm Post subject: |
Thank you, that is helpful, it should just fit. I'm getting the bike on Monday now instead of Friday so I'll post pics early next week. I'm very excited. |
