mirrors for DB series
PostPosted: Tue Jul 28, 2015 9:11 pm    Post subject: mirrors for DB series Reply with quote
I managed to break off the right side mirror of my DB5R. I found a replacement at moto-science.com, and he appears to have mirrors for the whole series. Of course with the DB5 series the only thing that you can see is your foot, so I remove the glass with a heat gun and then remove the guts with a phillips screwdriver. I then bend a piece of brass sheet to fit in the well that the tilt bit rests in and shape the outer edge of it to tilt the bottom of the mirror out. Reassemble with double stick tape for the glass and you're in business!
Spike C.
1965 Triumph T100SC
