big end bearings sizes and pic of my build
Goto page 1, 2, 3  Next
EYREY1
PostPosted: Wed Aug 26, 2015 12:20 am    Post subject: big end bearings sizes and pic of my build Reply with quote
does anyone know the sizes of big end bearings please ?
piero doesnt have any, my engine is stripped
and i need to get the cranks sent off
anyone ?
ive emailed piero and im hoping he can tell me and if he does i will post here
PostPosted: Wed Aug 26, 2015 8:40 am    Post subject: Reply with quote
That looks like the same set up as mine
The Fag type slip bearing
I will dig them out tomorrow if needed
but you can measure them when apart
Are you going to full premix ?
Bike looking great , real nice job
Cheers Trev
EYREY1
PostPosted: Thu Aug 27, 2015 12:10 am    Post subject: Reply with quote
if you can send me a pic and give me big end bearing size that would help Trev so i can order them now
im going to be running the bike on the pump ,
the normal ones into the cranks and the other 2 lines are going to the carbs ,1 each and the feeds are going on the inlet part of the carb like kr1s ,tzr,
this is just a rough build , once its running and everything on and working i will strip it again and get it all painted ,plastic coated ,and nicol plating it should be nice once done
PostPosted: Fri Aug 28, 2015 3:22 am    Post subject: Reply with quote
Whats your email again ?
Got the rod spec's etc
Trev
PostPosted: Sat Aug 29, 2015 12:16 am    Post subject: Reply with quote
I dilled holes for oil feed and slotted conrods
Just like a GP bike , mine is Wink
Cheers Trev
EYREY1
PostPosted: Sat Aug 29, 2015 3:52 am    Post subject: Reply with quote
i will pm you my email trev
explain and pics please ?
gufi
PostPosted: Sat Aug 29, 2015 7:18 am    Post subject: crank and bearings Reply with quote
sorry dont know how to upload fotos..
But I can deliver all bearings and also crank rebuilding with "normal" conrods and better lubrication oil supply. "Racetrack tested, 125 HP"
We have all parts for motor, platics etc. for Vdue
We can keep you running.
Guido
info@motorrad-fiedler.de
EYREY1
PostPosted: Mon Aug 31, 2015 12:39 am    Post subject: Re: crank and bearings Reply with quote
Guido
hi Guido good to hear from you again
can you look at the pics above of my crank cases please and the bearings ,what needs doing to make this a reliable motor ?
i was told that the engine had some mods done by the race team to
sort out the crank problems , ?
how would i know if it had ?
the mains are ok ive had someone look at them today but one of the big end bearings needs changing so getting both done while they are in bits ,
any advice you can give would be appreciated !
like how your getting better lubrication to the big end bearing ?
im having auto lube into the pwk carb same as normal 2 strokes and also keeping the 2 feeds into the cranks .
will it be ok like that ?
GARY
PostPosted: Mon Aug 31, 2015 10:35 am    Post subject: Reply with quote
Hi Gary
They are modded cases
not the standed set up
Cheers Trev
EYREY1
PostPosted: Mon Aug 31, 2015 11:36 pm    Post subject: Reply with quote
thanks trev
can anyone tell me what the mod is ?
how to tell if its been done
PostPosted: Mon Aug 31, 2015 11:45 pm    Post subject: Reply with quote
Your set up was the 500 cup bike mods
I run the same set up
but with even more up grades
- drilled cases for fuel mixture to main bearings
- slotted con rods
- no case oil feed , just premix
Run for years like this no problem
Cheers Trev
EYREY1
PostPosted: Tue Sep 01, 2015 2:01 am    Post subject: Reply with quote
THE DRILLED CASES YOURS HAS DONE IS THAT
looking down where the barrels fit either side of the con rod there is a hole drilled at each side with a chamferd bowl shaped bit to catch more oil ? if yes mine has those also
or is it a different drilled cases ?
my engine is no 25 trofero so was a race motor
PostPosted: Tue Sep 01, 2015 9:02 am    Post subject: Reply with quote
Yours is same same then
Lucky boy they go well
You just need some rod kits then Wink
Cheers Trev
Joe Johnston
PostPosted: Tue Sep 01, 2015 9:57 pm    Post subject: Reply with quote
Hi are the con rods unique to v due's
Kawasaki H2c
Yamaha RD400E
V Due
EYREY1
PostPosted: Wed Sep 02, 2015 2:07 am    Post subject: Reply with quote
its just getting some new big ends ,
joe i dont know about the con rods
ask piero or guido i think piero has some up grade ones that are a but different to std ones , i dont know what guido has but he does have some also
Page 1 of 3
