DB6 Pegaso ECU
Goto page Previous  1, 2
Number2
PostPosted: Mon Oct 02, 2017 4:31 pm    Post subject: Reply with quote
socpatrick wrote:
Mine is fir Walbro. Sorry.
Will the software you have work on the DB7?
PostPosted: Mon Oct 02, 2017 5:32 pm    Post subject: Reply with quote
Nope....DB5 and DB6 and Tesi3D all use Walbro 1....DB7 uses Walbro II....different programmes
Looka
PostPosted: Sun Nov 26, 2017 7:54 pm    Post subject: Diagnostic software and cable for DB6 Reply with quote
Im am also in need of the diagnostic software kit for the Delirio with Walbro ECU.
As for the cable, as long as I know the Walbro has a serial connection. The bimota connector should have this scheme.
Pin 1 not to be connected;
Pin 2 RS232Rx
Pin 3 RS232TX
Pin 4 Ground
I _think_ that a it should work even with a USB/RS232 converter and should be easy to do. I volonteer to try if someone pass me the software, and send back the cable if I succed Smile
Looka
PostPosted: Tue Jan 16, 2018 3:06 pm    Post subject: Diagnostic software + cable DB6 Reply with quote
I got both cable and software.
If someone needs them just send a pm.
Page 2 of 2
