Yoke nut issue.
luciousesox
PostPosted: Sun Jan 31, 2021 10:18 pm    Post subject: Yoke nut issue. Reply with quote
Sorry if i am annoying anyone with me constant posts.
I’m getting to the stage where I think that I’ll never get to ride this bike, seems that it’s one problem after another.
This time I decided to give it a good look over to check it would go through the MOT with no issues, forks seem to have too much play so I took the top yoke off and found a split nut , any ideas where to get one or if there is another bike with the same threads l.
Bimota YB9, RD500,Z1 1974,Z1 1975, Benelli 750sei, 900sei, GPZ 750 turbo, Rudge super sport, S.O.S, BSA Rkt 3 1969, 1966 Bonnie, Egli Vincent 1954,Guzzi 850T, Commando fastback, Commando Interstate, Enfield Interceptor 69, 72 H2, 69 H1, Suzy Gt750 J
PostPosted: Sun Jan 31, 2021 10:45 pm    Post subject: Reply with quote
Hi mate, new threads on the forum are always welcome and there’s always info shared that benefits many members, not just the OP.
Many of the early Bimotas used the same threaded collar. Centrepoint wholesale in Australia has a few of them for sale on eBay.
luciousesox
PostPosted: Mon Feb 01, 2021 12:40 am    Post subject: Reply with quote
I hate to be a pain but I have tried searching the site you suggested but I don’t seem to be able to find it. Would you be so kind as to put a link up if possible please.
PostPosted: Mon Feb 01, 2021 7:00 am    Post subject: Reply with quote
Search on bimota-parts.de its in English and German...rudolf has had them remanufactured....its a milled from billet bimota specific piece....often the clamping bolt is over tightened causing that split.... https://www.bimota-parts.de/en/component/virtuemart/yb9/lenkkopfrohrmutter-detail.html?Itemid=470
PostPosted: Mon Feb 01, 2021 1:49 pm    Post subject: Reply with quote
Hmm, I can’t find the ones that were on eBay from Centrepoint.
I think I have a spare in my stash
luciousesox
PostPosted: Mon Feb 01, 2021 2:44 pm    Post subject: Reply with quote
Thank you for the offer, very much appreciated however I have ordered one from Rudolf in Germany, a bit steep at €93 inc shipping + import duties but needs must.
Thanks to everyone for all the help and advice, one day it will get on the road.
PostPosted: Mon Feb 01, 2021 11:11 pm    Post subject: Reply with quote
Good news. As 2bims says above...... don’t over tighten it.
PostPosted: Tue Feb 02, 2021 11:38 pm    Post subject: Reply with quote
AAAgh. Have you definitely ordered? If not........I just posted this evening in DB section. I had the very same issue with my DB2 and got a part made up locally. Don’t know if its the same dimensions but I think YB9 had same 41mm forks as DB2 so probably?
PostPosted: Wed Feb 03, 2021 12:58 am    Post subject: Reply with quote
Ya muppet Ralf.....what are you doing with your time? Retired...Corona Lockdown...We should be seeing a fleet of pristine Bimotas rolling out of your garage by now.....And...Poor Paolo of Bimota Classic Parts has now lost some revenue....if he bothered to venture onto here and look after us all...he could have jumped in before me and Brian and posted up and helped out...HeyHo...he must be a busy man.... Laughing
PostPosted: Wed Feb 03, 2021 12:59 am    Post subject: Reply with quote
Oh....and maybe not....Fork tube sizes are irrelevant for the central steering stem....maybe it would fit...maybe it wouldnt....DB2 frame is CrMo round tubing...YB9 is alloy perimeter beam and headstock....
PostPosted: Wed Feb 03, 2021 10:25 am    Post subject: Reply with quote
Sort of glad if it wasnt the same , just wished i’d posted up sooner to give lusciosesox another option. Heh-oh!
luciousesox
PostPosted: Fri Feb 05, 2021 7:17 pm    Post subject: Reply with quote
The saga continues, the new ( expensive ) part I bought is incorrect on the outer diameter, too small to go over the frame and clamps on the frame. I could fit washers onto the head bearing but that would allow dirt into the bearing ????
luciousesox
The saga continues, the new - expensive - part I bought is incorrect on the outer diameter, too small to go over the frame and clamps on the frame. I could fit washers onto the head bearing but that would allow dirt into the bearing ????
luciousesox
PostPosted: Fri Feb 05, 2021 7:18 pm    Post subject: Reply with quote
The saga continues, the new - expensive - part I bought is incorrect on the outer diameter, too small to go over the frame and clamps on the frame. I could fit washers onto the head bearing but that would allow dirt into the bearing.
PostPosted: Fri Feb 05, 2021 10:40 pm    Post subject: Reply with quote
I’ll check my stash and see what I have there.
Post the dimensions of your broken nut and I’ll see if I can help you out
