spidermaan
Posted: Sat Nov 28, 2015 8:32 am Post subject: Light indicator and stop light for DB5 |
Does anyone of you know if light indicator (front and rear) of Benelli Tornado 900 (1130 perhaps too) and TNT1130 mount on DB5/DB6? In my opionione they are the same pieces, but I never can try to mount or see better. Does someone try to mount?
Perhaps for the stop light its the same. _________________ http://bcomebimota.blogspot.it/ |
spidermaan
Posted: Sat Nov 28, 2015 9:42 am Post subject: |
Yes youre right....the Benelli rear stop light is the same as Bimota use on the Db5 and Db6.....rear indicators are the same as for the DB5...but not the Db6....Front indicators on the DB5 are the same as used on the Benelli...But...Bimota fit the left one on the right hand side....and the right one on the left hand side...as they fit them 180 degrees the other way around....thin part at the front and fat part at the back...if you understand what I mean....so if you need a front right indicator....you order a front left indicator off a Benelli...as they are different shapes on both sides.... |
spidermaan
