franky
Posted: Sat Dec 19, 2015 10:12 am Post subject: Sb7 model history |
Hi all.
Having just purchased an sb7 I'm trying to find all the background info/pics about this model? The yb8e that I got at the same time seems a little easier to get info on.
Its been standing a while so will need teasing back into life. |
djk
Posted: Tue Dec 22, 2015 5:53 am Post subject: |
Hey there ive got a SB7 as well and the first thing I always say is the fuel injection is shocking below 5-6k, a power commander helps but doesn't totally fix it from what ive read, other options are an aftermarket ecu, I think motec does something but that would mean dyno time to set up.
Other than that my knowledge is that it was made to race in superbikes back in the nineties using the GSXR750SP motor of the time. 200 SB7s supposedly made but who knows, 130ish made in the red/white/purple colours and 70ish made in black/yellow/purple colours, unsure correct quantities.
My bike sat for a while and I emptied the tank and put fresh fuel in and it fired after a few presses of the button, luckily I had the batteries(2 of them) on a tender so they were okay. I forgot that in the plastic tank fuel goes off sooner, I have seen images of the fuel pump hoses in the tank degrading over time so could be worth having a look through the filler cap to see if they are okay.
My bike did a base run on a dyno when it landed in NZ and they said it was doing roughly 120hp at the rear wheel.
I like my SB7, fuel injection problems aside(just keep it above 6k and no problems) it is one of my dream bikes. |
franky
Posted: Tue Dec 22, 2015 8:55 pm Post subject: |
Hi, Yes can't wait to try and get it going again. I'm not too worried about it being lump/rubbish low down. Its just a fun type bike.
Great history to them also
I've not managed to find any actual dyno testing of them? I thought they might make about 110bhp at the wheel? |
djk
Posted: Wed Dec 23, 2015 3:50 am Post subject: |
On one of the web pages I found they had 98.4kw/132hp as the maximum power which im guessing is at the crank. The motor cycle shop that I brought my bike from put all the fresh imports on the dyno to give them a run to make sure the bike is running right, 120hp is what I was told but no sheets printed so I cant verify, dyno results can vary as well so it could be plus or minus. I do remember the mechanic was surprised it was making that much. |
Posted: Wed Dec 23, 2015 12:25 pm Post subject: |
On the SB6 it's the airbox that restricts the performance so I guess it doesn't affect the 750 so much. The exhaust is thought to be good or at least better than OE Suzuki _________________ Don't read everything you believe |
djk
Posted: Thu Dec 24, 2015 8:51 am Post subject: |
Ive read one magazine article that said Bimota added its own cams to this model but they also said that about the SB6 but I think that was disproved? I did do a search and they said the 1994 Suzuki GSXR750 SP motor was making 118hp but didn't say if it was at the crank or rear wheel. Most of that power is at the top end too with hardly anything down low. |
Posted: Fri Dec 25, 2015 5:55 pm Post subject: |
The SB6 uses standard Suzuki cams. The later Suzuki Gsxr1100w used Yoshimura profiles .... which were similar to the 750 profiles.
I doubt Bimota changed the SB7 cams either _________________ Don't read everything you believe |
franky
Posted: Fri Dec 25, 2015 9:02 pm Post subject: |
Evilchicken0 wrote: |
I doubt Bimota changed the SB7 cams either |
From what i "know", thats where the extra power came from, the japan only engines were made to a 100bhp limit, all bimota did was fit the cams the engine should have had. |
