Sb8 problem from 5000 to 7000
biturbo
PostPosted: Thu Jan 07, 2016 9:16 pm    Post subject: Sb8 problem from 5000 to 7000 Reply with quote
After installing the power commander in my sb8 the smoothness of operation improved a lot at low speeds and small openings of the throttle body but still remain a problem of regularity of operation from 5000 rpm to 7000 at big and fast openings. my mechanic at this point do not think would be a carburation problem but thought could be a problem with ignition ( coils or other) .
Could be an ecu problem ??
At high revs the engine in works well and is also very powerful now over 123 rwhp
Since many bikes seem to suffer from similar problem i would like to know if this problem is common or only my suffers ?
someone has solved ?
wdm
PostPosted: Sun Jan 10, 2016 8:15 pm    Post subject: Reply with quote
biturbo - could be your TPS. see:
http://www.bimotaforum.co.uk/viewtopic.php?t=3911&start=0&postdays=0&postorder=asc&highlight=
biturbo
PostPosted: Sun Jan 10, 2016 10:41 pm    Post subject: Reply with quote
Tkanks a lot !! i will try and i let you know if the situation will improve
biturbo
PostPosted: Sat Feb 06, 2016 4:55 pm    Post subject: Reply with quote
Problem solved !! Now the bike runs very good !
the temperature sensor in the radiator is ' placed in too Hight position so if the circuit is not completely full creates problems to the map
SB8R Tuner
PostPosted: Sat Feb 06, 2016 6:56 pm    Post subject: Reply with quote
That's funny, the temp sensor in the radiator is for the temp gauge in the dash. The temp sensor for the ECU is mounted in the thermostat housing under the airbox. I'd make sure you don't have any wires crossed up.
Bimota SB8R
Bimota V-Due
Bimota SB8R
Suzuki 1988 GSXR-750
Suzuki 1989 GSXR-750R
biturbo
PostPosted: Fri Mar 18, 2016 4:46 am    Post subject: Reply with quote
Yes infact the problem returned but now is finally solved the problem was the tps sensor.
