SB6R - front brake micro switch
stox
PostPosted: Wed Jan 13, 2016 9:46 am    Post subject: SB6R - front brake micro switch Reply with quote
My front brake light isnt working so i'm going through all the likely causes and first off is the switch.
Has anyone got the part number or technical details for the front brake micro switch?
I know its a DC1 but there about 30 or so different options.
PostPosted: Wed Jan 13, 2016 2:45 pm    Post subject: Reply with quote
Does it have a number on the back of it ?
It's a goldline master, they used them on Ducati 916 etc but you can try Mode Performance, they're a Brembo official importer.
I assume you've shorted out the switch and the brake light comes on ?
stox
PostPosted: Wed Jan 13, 2016 4:26 pm    Post subject: Reply with quote
How do you do that?
(im an electrical numpty)
stox
PostPosted: Wed Jan 13, 2016 5:56 pm    Post subject: Reply with quote
Figured it out, works on the short.
The switch is at fault.
That's made me happy as I was dreading pulling the loam apart.
PostPosted: Wed Jan 13, 2016 10:24 pm    Post subject: Reply with quote
It's just a bike Smile
There should be two small screws holding the switch to the master unscrew them and look for a code on it.
PostPosted: Wed Jan 13, 2016 11:40 pm    Post subject: Reply with quote
Mine was playing up when I first got my sb6 too. I pulled the switch apart and cleaned the contacts and applied some dielectric grease. Good as new.
Warning... There are tiny parts inside the switch, spring and contacts etc. be careful when you pull it apart that bits don't fly out.
PostPosted: Wed Jan 13, 2016 11:42 pm    Post subject: Reply with quote
The other possibility is the adjustment of the switch. It was difficult to get the switch in exactly the right position for it to work. Very fiddly job
stox
PostPosted: Thu Jan 14, 2016 11:29 am    Post subject: Reply with quote
Thanks all.
New switch ordered for £5, thats a lot better than the £30 Ducati wanted.
PostPosted: Thu Jan 14, 2016 6:17 pm    Post subject: Reply with quote
Nice one Cool
