Posted: Wed Jan 13, 2016 4:55 pm Post subject: Sprockets and gearing |
1) standard sprocket ratios on DB2 15/37. Thinking of going to 39T rear on my standard engine bike to aid acceleration. If I had 100 HP+ (you 944cc boys out there!) then 37 might be enough. Any DB2/4 users played with their gearing??
2) after ordering a DB2 specific 15T sprocket from AFAm it was of course not right. Looks like Wieres in Germany is the only supplier that's proven?
Before I pull the trigger
-Anybody used a Wieres DB2 sprocket
-Anybody else want to order at same time as €15 p&p on a €25 item gets my goat..however understandable. _________________ Not as many bikes as I would like and already too many to keep up with! |
Posted: Wed Jan 13, 2016 6:50 pm Post subject: |
standard Ducati sprocket for 900ss will do, just get local engineering shop to turn the centre out for the location washer by 2mm if I remember correctly. See pic in your DB post thread  _________________ KB1x2, SB3 SB4 BB1 DB2 Vdue Evo YB11 RB1 Ducati MHR Suzi GS650 |
Posted: Wed Jan 13, 2016 7:20 pm Post subject: |
| Already got myself a couple of spares...one of which I had put aside for you.......Yeh...machine shop can turn out a standard...Vort had it done for his DB4 that shares the same issue...machine shop wasnt happy though after doing it...cost them 3 hardened bits in the process to turn out from a hardened front sprocket...... |
