Spring
Joined: 16 Nov 2010 Posts: 106 Location: South Coast UK
Posted: Wed Jan 27, 2016 4:52 pm Post subject: SB6 Brake+Clutch M'cylinders? |
Hallo all, I'm in need of original Clutch M'cylinders and Brake M'cylinders.
Mine came with Lockheed+Suzuki? Items. Brembo I know but model part no;
I don't. Anyone had an upgrade? |
Posted: Wed Jan 27, 2016 5:23 pm Post subject: |
The original SB6 Mk2 on were Brembo Goldline, they were used on Ducatis and lots of Italian bikes of the time.
I've used a Ducati 1098 radial clutch master and a Brembo Race brake master cylinder with a pressure switch. It's a bit easier now to get a brake master with a microswitch for brakes, they're a bit more accurate than the pressure switch.
Spring
Posted: Thu Jan 28, 2016 3:45 pm Post subject: |
Thanks for that,guess Evilbay it is then |
