Injection
Goto page 1, 2, 3  Next
Matty82
PostPosted: Thu Jan 28, 2016 9:41 pm    Post subject: Injection Reply with quote
Hi everyone, I take it no-one is getting out at the moment ( me included.) thought I would start work on my injection bike, it starts runs for a few seconds then cuts out. Is anyone experienced enough to look at it in the uk? Or is it best taking her to Mr VDue ( Piero )
2SMOKE
PostPosted: Thu Jan 28, 2016 10:43 pm    Post subject: Reply with quote
Have you been threw the simple things first
the keep it simple stupid checks , KISS etc
they are easy to work on
Cheers Trev
Matty82
PostPosted: Thu Jan 28, 2016 10:58 pm    Post subject: Reply with quote
Talk to me Trev, as I'm new to this one
2SMOKE
Matty82
PostPosted: Thu Jan 28, 2016 11:02 pm    Post subject: Reply with quote
Battery voltage is good, fuel is good, plugs look new, runs fine ( when running)
When it stops, just turn ignition right off, ecu resets, starts again
2SMOKE
PostPosted: Fri Jan 29, 2016 10:14 am    Post subject: Reply with quote
What numbers is on the blue and black box under the tank ?
The black one is the brain the blue is the data recorder
Trev
BOFFER
PostPosted: Fri Jan 29, 2016 11:58 am    Post subject: Reply with quote
Hi Matty, it does sound oike the blue and black boxes. Had lots of chats with piero about this topic and the outcome was that low numbered boxes were not that good and you need to try big numbered boxes of which Piero had loads spare. I had a load but gave them to my vdue fixing hero based down in Nottingham.
Matty82
PostPosted: Fri Jan 29, 2016 12:20 pm    Post subject: Reply with quote
Right no's are;
Blue 00004 and Black 00309
Hey boffer could I have you're hero's number as that'll prob be quicker than shipping from Italy Smile
2SMOKE
PostPosted: Fri Jan 29, 2016 12:25 pm    Post subject: Reply with quote
As Trev/Boffer already said, not all vdues are equal and injections can be all over the place.
Where did your bike come from ?
Is it 100% original sat in a collection/never run injection
Played with one
A Piero reworked one ?
BOFFER
PostPosted: Fri Jan 29, 2016 12:32 pm    Post subject: Vdue injection Reply with quote
To be honest Matty, it could be lots of things and its probably a mix of a few things. Mine had exactly the same problem and it turned out to be the fuel filter crumbled to sand after 15 years in storage and clogged up the fuel tank hence it would start but then starved of fuel and stopped just as quick. It could be electrical and you will know if it is because the clocks will go haywire if you have leccy problems although I did fix this on mine. Could also be the blue and black boxes and your blue one looks like a first run of boxes that were faulty.
Matty82
PostPosted: Fri Jan 29, 2016 12:37 pm    Post subject: Reply with quote
Hello vort, ya I'm with you, these special an individual things. What works for one may not work for another but we have to try, ha.
It's done a small mileage but not in my hands. It had ti pipes on, which I've not seen on an injection before. The engine has been upgraded by Piero.
2SMOKE
PostPosted: Fri Jan 29, 2016 1:14 pm    Post subject: Reply with quote
When you say Titanium pipes, is that in the usual inj config ? or JM straight through config ?
Have only seen ti pipes in pictures and struggling to remember where, think it was a bike in the states.
Matty82
PostPosted: Fri Jan 29, 2016 1:22 pm    Post subject: Reply with quote
Looks wise I would say like the Trofeo
2SMOKE
PostPosted: Fri Jan 29, 2016 1:32 pm    Post subject: Reply with quote
Bet they must look good. Shocked
Only ever run inj on standard pipes , so not sure if they have a contribution to issue.
Matty82
PostPosted: Fri Jan 29, 2016 1:45 pm    Post subject: Reply with quote
Yep, putting everything to standard an then work from there.
Pipes are as trick as JM's an also dont rust, perfect Smile
2SMOKE
PostPosted: Sat Jan 30, 2016 12:05 am    Post subject: Reply with quote
The black box numbers need to be over 500
The blue box only records data
Check the KISS things first
and get a new black box
Trev
Page 1 of 3
