SB6 MK1 HEADLIGHTS
Pohlen180
PostPosted: Mon Feb 01, 2016 4:39 pm    Post subject: SB6 MK1 HEADLIGHTS Reply with quote
Hi All
Can anybody tell me what the headlights in a MK1 (125mm) are from and will they fit in my MK2 (135mm) as i've picked up a MK1 fairing and tail unit so need to change the headlights.
Thanks.
Z9 B1, Z9 modified, RD 500, ZXR750RR K1, GSXR1100WP, ZX9R, ZRX1200, SB6
PostPosted: Mon Feb 01, 2016 7:17 pm    Post subject: Reply with quote
Gsxr 400 or zxr400 I believe
Pohlen180
PostPosted: Mon Feb 01, 2016 9:17 pm    Post subject: Reply with quote
Thanks is that standard lights or upgraded for night driving?
PostPosted: Mon Feb 01, 2016 11:16 pm    Post subject: Reply with quote
I think that's the standard.
If you want night driving then get a pair of H4 lamps and have them mounted on an alloy plate.
You could buy the ZXR / gsxr headlights and use them as a pattern
Pohlen180
PostPosted: Tue Feb 02, 2016 10:22 am    Post subject: Reply with quote
the headlight unit in it is plastic and the lights are 128.8mm dia, but being moulded into the plastic mounting plate I cant reuse the plate, so ideas please.
PostPosted: Tue Feb 02, 2016 10:38 am    Post subject: Reply with quote
There's a thread on here about a mod done to sb6 lights, mounted in a handmade aluminium plate.
PostPosted: Tue Feb 02, 2016 10:41 am    Post subject: Reply with quote
Here...
Quote:
http://www.bimotaforum.co.uk/viewtopic.php?t=2190&postdays=0&postorder=asc&start=60
PostPosted: Tue Feb 02, 2016 10:43 am    Post subject: Reply with quote
Try this one
PostPosted: Tue Feb 02, 2016 11:22 am    Post subject: Reply with quote
Some owners cut the lights out and mount new lamps on the plastic back plate. You might want relays if you go for higher wattage bulbs
Pohlen180
PostPosted: Wed Feb 03, 2016 10:23 pm    Post subject: Reply with quote
Thanks for the replies I'll get my friend to make up a plate like the one above.
Cheers everybody
