V10LEE
Posted: Mon Feb 08, 2016 10:18 pm Post subject: Going to buy a YB8 |
Im going to buy a YB8, but I have two to choose from. One is a 1991 and the other is a 1992. The 92 bike if fuel injection and the 91 has carbs. Which one is more reliable? Fuel injection? Both bikes have low mileage and are in top condition. Thank you .. |
Posted: Tue Feb 09, 2016 8:23 am Post subject: |
Never ridden a YB8 but have ridden a yb9 injection .
I would go for the carbs, have you ever ridden a early injection bike ???? They are not great. |
V10LEE
Posted: Tue Feb 09, 2016 9:02 am Post subject: |
vort28 wrote: |
Hi Vort thank's. I also own a 91 Ducati 851 Superbike. It's FI and runs great. Never had any issues.
It's the YB8 Furano I am looking at. _________________ 2016 Viper ACR Extreme
2010 Viper ACR
1997 Viper GTS
Too many bikes |
Posted: Tue Feb 09, 2016 10:01 am Post subject: |
Small world, I've had 851/888 and ridden RC45's etc , all early injection bikes and they were OK'ish, but not great and carb bikes at the time were definitely better.
The YB9 injection I rode was from the UK Bimota dealer at the time and he told me it had the latest inj map to smooth it out. It was ok on full throttle but coming off throttle and then back on, corner entry to mid corner acceleration it was VERY rough, sort of reminded me of the GPZ750 Turbo I had , you had to brake early and drive into the corner to avoid the poor on/off throttle response/lag.
I would suggest you ride before you make your mind up. |
bimotabob
Posted: Sat Mar 26, 2016 11:25 pm Post subject: |
The YB9SRI has completely different injection to the Furano or Tuatara.
I can't comment of the TDD type but the Furano uses P7 the same as 851 and early 888 ducati, its a real good system. My bike runs real nice and gives 5.5L/100km on a highway. Got a mate to have a go for comparison as he owned a FZR1000 with the same engine and he said my injected bike went a lot better. incidentally its got higher gearing to pull than a standard FZR1000.
The injection on the Furano is a race system, its basic but allows for whatever tuning you want to do. The standard fuel map is good as weber marelli worked direct with them at a factory level so it should be sorted. People dissed them because they know nothing about injection or how to set it up. Its not like the 2-stroke Bimota attempt. In all fairness the FZR1000 carbs are not very good for performance, they wear out quick too. My injection system is all still going after 25 years and i'm guessing the lower spec carb models be looking at their second rebuild. _________________ YB8EI |
sb8rs
Posted: Sun Mar 27, 2016 2:36 pm Post subject: |
I agree the YB4IE, YB6 Tuatara and YB8 Furano all used the same injection system.
It was cutting edge at the time and it worked well.
The later TDD system (SB7 and YB9sri) can be made to work with perseverance.
The Magnet Marelli system on the SB8 's, in my opinoin; needs the help of a power commander. |
bimotabob
Posted: Tue Mar 29, 2016 7:39 am Post subject: |
I didn't know the SB8 had a magnetti marelli EFI system, i thought after the Yamaha's they went TDD - what model is it do you know?
Incidentally i have been informed you can run a MV Agusta power commander on the MM P7 Yamaha fuel injection to make adjustments which could benefit people.
I found these pictures below from Japan, I didnt know TDD made fuel injection for the Furano's, wonder how many had this or perhaps it was done aftermarket for people wanting to swap. looking at the bracket and smaller box id guess Bimota released these during final production. The guy was swapping to haltech EFI by the looks
