Posted: Sun Feb 14, 2016 5:43 pm Post subject: YB10 oil idiot light doesn't come on |
The oil light on the cluster is supposed to go on when the key is in the ON position, which mine doesn't. Not sure if it's the bulb or the sender unit. its very difficult to get to the wiring with the tester without removing the front fairing. Are the idiot lights plugged in into the back of the cluster? What's the best way to access them? _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Posted: Sun Feb 14, 2016 11:14 pm Post subject: |
It might be easier to access the oil pressure switch and test it first? _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Sun Feb 14, 2016 11:28 pm Post subject: |
Where is the switch? _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Posted: Mon Feb 15, 2016 4:19 am Post subject: |
I'm not familiar with Yamahas, but it should be just screwed into the engine block somewhere. Maybe down near the oil pump. It will just be a round switch that screws into an oil gallery, usually only has a single wire. _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon Feb 15, 2016 4:26 am Post subject: |
Thanks Brian. I'll check in with FZR crowd. _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Posted: Mon Feb 15, 2016 4:51 am Post subject: |
2001 MV F4
2004 BMW R11S BCR
bimotabob
Posted: Sun Feb 21, 2016 7:56 am Post subject: |
The bulb lights in the crank position.
Check the bulb
The level sensor operates so that it has continuity to ground when your level is good and no continuity when it is low.
Depending on your model you will have one of two types of oil light relay, these make the light work in such a way when you disconnect the sensor it should light up the bulb as a fail safe mechanism.
I had a relay fail but the bulb still lit up when cranked, so sounds like a bulb issue for you. The bulb takes its power from the instrument cluster so would be unusual for it to lose the +12V. And the cranking ground comes from the diode/relay block which us fairly reliable. _________________ YB8EI |
Posted: Sun Feb 21, 2016 8:25 am Post subject: |
What's the easiest way of accessing the bulb? I see the screws on the back of the cluster that apparently hold the retainer for the light panel section. Am I able to remove just the individual plug at the back of the cluster? _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
bimotabob
Posted: Tue Mar 01, 2016 10:08 am Post subject: |
It can't be too advanced, bulbs made to be changed. I'm running ZXR400 bulb cluster so can't advise but i'm sure you will work it out, Heck there are much harder maintenance tasks to be done with the Bike. Your gonna struggle with sparkplug replacement! _________________ YB8EI |
Posted: Tue Mar 01, 2016 3:36 pm Post subject: |
I guess this will be my project for the weekend though the weather is just perfect for riding. Somehow I'm not looking forward to doing s plug job _________________ 1991 Bimota YB10
2001 MV F4
2004 BMW R11S BCR
Posted: Thu Mar 03, 2016 12:35 am Post subject: |
I can't speak for the yb's, but on sb6 it's even a pain in the arse to get oil back in the engine _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Thu Mar 03, 2016 12:36 am Post subject: |
brian wrote: |
I can't speak for the yb's, but on sb6 it's even a pain in the arse to get oil back in the engine |
Not to mention bleeding the clutch slave _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Thu Mar 03, 2016 12:37 am Post subject: |
brian wrote: |
brian wrote: |
Not to mention bleeding the clutch slave |
Or changing radiator hoses if you're really adventurous _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
