Stopping by the local bike shop.....
PostPosted: Thu Feb 18, 2016 2:09 am    Post subject: Stopping by the local bike shop..... Reply with quote
I was chatting with a fellow there and he showed me a DB4 that they had in for a service! It had a Florida plate on it. These are rare as hens teeth around here!
While chatting he asked me if I would like to put my bike on their digital scale that they had out, and of course I said yes. With a little over a half tank of gas it weighed right on 400#! Distribution was 51% front 49 back.
This is with an ally tank and a lithium iron battery. This agreed with my bathroom scale weighing one wheel at a time.
Spike C.
1965 Triumph T100SC
PostPosted: Thu Feb 18, 2016 4:34 pm    Post subject: Reply with quote
So that's 181kg and Bimota official figures seem to be 175kg in running order and 165kg dry.
7 litres of petrol is 4.9kg , so sort of lines up, other than the fact you have a light weight tank and a lighter battery.
PostPosted: Thu Feb 18, 2016 7:30 pm    Post subject: Reply with quote
The 50:50 weight distribution lines up also...I've had to Vosa test DB5/Db6 and Db7....and figures were always around 50:50...51:49....I know 50:50 is supposed to be good in a car but heaven knows if its also good for a bike? Evidently it varies tremendously when accelerating and breaking...so I suppose 50:50 is a good static starting point......
PostPosted: Fri Feb 19, 2016 7:39 pm    Post subject: Reply with quote
My thought is that a little weight bias to the front is a good thing, it helps keep the bike planted on turn in and reduces slightly the tendency to loft the front on corner exit. Of course, the front comes up exiting a turn underpower regardless, butt it sounds good!
Spike C.
1965 Triumph T100SC
