SB3 steering head beading
PostPosted: Sun Feb 21, 2016 7:30 pm    Post subject: SB3 steering head beading Reply with quote
Interesting taper roller bearings in the steering head with the bottom one larger than the top - not unusual. However the size is unusual at 26mm inner, 55mm outer and 18 mm deep?? Any ideas what it's off or where I can get one
Nige[/code]
Mike Jennings
PostPosted: Sun Feb 21, 2016 9:29 pm    Post subject: Reply with quote
Hello Nige-Does it have a makers name on it, or is that hidden by the steering head? I can't find it in the SKF or Timken catalogues.
Cheers, MikeJ
PostPosted: Mon Feb 22, 2016 12:32 am    Post subject: Reply with quote
I think the bearing inner is really 30mm and I don't have the correct stem for the bike. The steering head stem I have is 26mm parallel but I actually have a Suzuki one which is 30mm at the bottom and 26 at the top. May have to fit a bush. We'll see
