Falcolion
Posted: Sat Jan 30, 2016 9:32 pm Post subject: SB8K SantaMonica - Under the Gas tank Gasket |
I was wondering if anyone can snap a picture and share the dimensions of the gasket that is located under the gas tank. Length, width, width of each side and thickness and also a material it's made of - rubber, delrin, etc (Close guess is fine)
The part in question is number 19 - 506072075 on the diagram of parts fiche
Also if you got a picture of the part number 10 Spacer/Bushing it would be great as well
Thanks in advance _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega |
Posted: Mon Feb 01, 2016 1:39 pm Post subject: |
Hi Falcolion.
Is it the frame seal you are after ?
Is it the alloy or carbon tank you have ?
Posted: Mon Feb 01, 2016 2:14 pm Post subject: |
I love that shower system... sexy as hell! _________________ '99 DB4 #104, '96 SB6 #1165, '94 DB2 J #652, '99 DB4 #088, '08 VTX1800, '93 ZXR750R M1, '95 ZXR750, '95 ZXR750 Race Bike, '94 CBR400rr NC29 Race Bike, '94 CB250, '49 BSA C10 250, '61 BSA A10 650, '89 ZXR750, '91 Ducati 851 |
Posted: Mon Feb 01, 2016 3:39 pm Post subject: |
I will not ask what shower scene you have been watching !!
If you speak to me nicely I will take a video of the shower in full flow !!!  |
Posted: Mon Feb 22, 2016 1:48 pm Post subject: |
Finally got a few minutes to spare so got a few pictures.
The gasket tank-frame is 5mm think and 10mm wide and made out of close cell neoprene by the looks of it.
The tank bush to hold tank down is and alloy L-shape sort of thing , with a plan view
Its 20mm wide 25mm long and 15mm deep. This is for the carbon tank. Not sure if alloy tank is the same.
end view
Falcolion
Posted: Mon Feb 22, 2016 4:29 pm Post subject: |
Thanks guys. I have the gasket. What I am concerned/asking about is there something that goes under the front of Aluminum gas tank right where the screw is inserted.
In other words if you look at both of these pics you see 3 holes - the middle one for the screw and the 2 others, my assumption, are for some kind of rubber/delrin insert with 2 prongs. My assumption that if that particular rubber/delrin insert has little fangs/extensions that go into 2 sides holes and prevents it from sliding around.
Thank you very much for trying to help
Vlad _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
Posted: Tue Feb 23, 2016 7:56 am Post subject: |
Spare alloy tank I have looks to have a fairing type attachment, alloy spacer with rubber mount. However , never fitted it so wouldn't really know.
Maybe the 2 countersunk holes are from the SB8R setup.
