Front wheel for SB3
Mike Jennings
PostPosted: Sat Feb 27, 2016 5:05 pm    Post subject: Front wheel for SB3 Reply with quote
Hello,
I'm looking for a front Campagnolo wheel for a Bimota SB3.
Cheers, MikeJ
waggy
PostPosted: Sat Feb 27, 2016 9:34 pm    Post subject: Reply with quote
What about this one,
http://www.ebay.co.uk/itm/CAMPAGNOLO-WHEEL-DUCATI-BEVEL-NCR-BIMOTA-TZ-YAMAHA-SUZUKI-HONDA-KAWASAKI-AHRMA-/331788192284?hash=item4d401e0a1c:g:9bEAAOSwbdpWZ0~m
PostPosted: Sun Feb 28, 2016 5:56 pm    Post subject: Reply with quote
Hi Mike, what's up with the one you have? The campag above, if it's like mine that can fit a Yam is wider across the hub and the standard brembos and carriers won't fit - the discs are too wide apart. Also you can't fit a speedo drive as you only have 10mm I think at either side. I had some carriers and discs made at a good price. Mailme and I can send you a couple of pics
Nige
Mike Jennings
PostPosted: Mon Feb 29, 2016 10:15 am    Post subject: SB3 wheel Reply with quote
Hello Waggy and Nige,
thanks for the replies. The original Campag. was dented and Hagon's couldn't straighten it so it's out of action, unfortunately. I've fitted a replacement wheel which also needed special carriers made but it's a small flanged Speedline or something similar which doesn't match the rear Campag. so I thought I'd see if anyone had the correct wheel. There's no rush on the bike as I've been fiddling with it for about twelve years now- it'll probably end up being left to a museum in my will!
Cheers, Mike Laughing
