Need rear sprocket for DB5R
PostPosted: Mon Mar 07, 2016 7:05 pm    Post subject: Need rear sprocket for DB5R Reply with quote
Does anyone know where to get a rear sprocket for the DB5R? Mine is loosing teeth at a rather prodigious rate. It has the OZ wheels.
Spike C.
1965 Triumph T100SC
PostPosted: Tue Mar 08, 2016 8:32 am    Post subject: Reply with quote
My Tesi was supplied with a supersprox alloy/steel sprocket on Oz wheels.
Part number seems to be 2698 if you are interested
PostPosted: Tue Mar 08, 2016 7:02 pm    Post subject: Reply with quote
Thanks Vort!
Spike C.
1965 Triumph T100SC
PostPosted: Tue Mar 08, 2016 7:07 pm    Post subject: Reply with quote
Well, I have tried to use the Supersprox web site and every search ends in a 404 message. 🤔
Every sprocket I find that is speced for OZ wheels has a 76mm center hole or 5 bolts. I have a call into Bob at BS, so we shall see if he can come up with something.
Spike C.
1965 Triumph T100SC
PostPosted: Sat Mar 12, 2016 3:24 am    Post subject: Reply with quote
I finally gave up and ordered a rear sprocket from Bomota Spirit, it had to come from Italy, and was $168! Sheesh!
Spike C.
1965 Triumph T100SC
PostPosted: Sat Mar 12, 2016 10:56 am    Post subject: Reply with quote
Spike, sorry I didn't reply earlier.
I just ordered 'special' from Renthall in UK. (39T for my DB2)
So long as you specify size, teeth and bolt fixing they can do.
My alloy (hard anodised) sprocket was a shade under £50.
Worth noting for future. I would be happy to get here in UK and fwd to you to avoid the dreaded import fees etc.
