spare parts wanted
fish
PostPosted: Fri Mar 25, 2016 6:19 am    Post subject: spare parts wanted Reply with quote
Hi all I have a set of Tecnomagnesio wheels on my yb6 .As the speedo has never worked and have brought gauges- speedodrive and cable to sort the problem out. Found that speedo drive had seized and has destroyed the drive ring for the speedo drive.Does anybody know who sells parts for these wheels cheers fish PS I work away from home and parts come up for sale before I checked it out
DB1-DB2SR-DB2EF-DB3-DB4 Db10 YB6-yb7_yb10-2xyb11-SB5,2xSB6-kb3-yb5-MILLE MIKEHAILWOOD HARRIS MAGMAN2-TRIUMPH T140-RG500x2-KAWA Z900-SUZUKI GSX1100-DUCATI 900SS- 750 sport ducati DUCATI F1 750- 851 tri colour-500sl-1996 Trumph datona . Vee two alchemy
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Fri Mar 25, 2016 11:13 am    Post subject: Reply with quote
Have a look at the remains of the drive ring, you can find its thickness if nothing else. Measure the drive to find the size of the lugs and do the same for the wheel.
Find a lazer cutting company and get a ring done.
This is based on the ducati type drive ring being cut from thin flat steel
fish
PostPosted: Wed Mar 30, 2016 5:11 am    Post subject: spare parts wanted Reply with quote
Hi thanks for advice evilchicken.Have found parts as they all are standard Yamaha parts cheers fish
PostPosted: Wed Mar 30, 2016 9:28 am    Post subject: Reply with quote
That's a result Very Happy
