Throttle Cable routing
JackJabba
PostPosted: Sun Aug 21, 2016 4:35 pm    Post subject: Throttle Cable routing Reply with quote
Can someone please post some pictures of the throttle cable routing on their bike. Mine is opening the throttle on full lock so looks like it needs re routing.
Does it run down the back of the radiator or through the gap between the left side frame spars next to the head stock?
Regards Jack
PostPosted: Mon Aug 22, 2016 5:35 pm    Post subject: Reply with quote
Not got a picture but mine run between the upper and lower frame rail on the LHS of the head stock, round the battery box , behind the rad and into the top of the carbs, if that makes sense.
Had a few of issues with cables getting caught and not sitting in top adjuster screw on carbs.
I have tried to re-route fuel lines etc to get throttle cables fitting better but think lithium battery and removing battery box to allow for better cable run is the way forward !!Just got to get around to doing it now !! Rolling Eyes
JackJabba
PostPosted: Mon Aug 22, 2016 7:42 pm    Post subject: Reply with quote
Thanks Vort, mine is the same. Going to fit angled throttle cable adjusters to help with the fitting.
