Pulling apart YB8 stock muffler
V10LEE
PostPosted: Thu May 12, 2016 9:04 am    Post subject: Pulling apart YB8 stock muffler Reply with quote
I'm restoring my stock muffler outer tube/skin. I drilled out the rivets. What's the trick in removing the end cap? Let it soak with some WD40 overnight?Or is heat the answer? It's on there tight . Thank you guys.
2016 Viper ACR Extreme
2010 Viper ACR
1997 Viper GTS
Too many bikes
djk
PostPosted: Fri May 13, 2016 9:29 am    Post subject: Reply with quote
For me if something is tight I would look for my rubber mallet/hammer to give it a few taps to see if that would free it up. If its on there tight I would say your idea of soaking it overnight would be a good start.
V10LEE
PostPosted: Sat May 14, 2016 3:51 am    Post subject: Reply with quote
Thanks djk. I heated it up with a hand held propane torch and used a soft mallet and tapped it off.
2010 Viper ACR
1997 Viper GTS
Too many bikes
V10LEE
PostPosted: Sat May 14, 2016 3:53 am    Post subject: Reply with quote
The inner muffler is a b_tch to take out. It doesn't budge one bit. Even used a wrench to grasp it. Does anyone know if the inside muffler is glued in or some sort?
2010 Viper ACR
1997 Viper GTS
Too many bikes
