Andy Robson
Posted: Sun May 15, 2016 6:59 am Post subject: Brembo parts, YB11 |
Can anyone help with identification/model number of the Brembo master cylinder for the clutch and the brake master cylinder.
I have just acquired a YB11 with some 10,500 km on it but the brake master cylinder is leaking. Information on these seems minimal along with repair kits.
Any help appreciated such as the dimension of the bores
TA
Andy Robson  |
yb11reno
Joined: 14 Feb 2015 Posts: 111 Location: Reno, NV USA
Posted: Wed May 18, 2016 5:56 am Post subject: |
I bought a replacement clutch master for my yb11 from oppracing.com
30805 Brembo oe clutch master cylinder p13 gold without reservoir w/lever 39 reg./
Cost was $163.92 not including shipping.
It was an exact match. _________________ Jack
Reno, NV |
Falcolion
Posted: Wed May 18, 2016 7:00 am Post subject: |
You can also get any 01-04 Aprilia brake and clutch levers _________________ 2016 Suzuki GSXR750 TRACK BIKE
2011 KTM RC8R
2010 Husaberg FE390
2008 BMW HP2 Sport
2007 Aprilia RSVR Bol D'Or
2006 Bimota SB8K Santamonica
2005 Benelli Tornado Tre
2002 Mondial Piega |
bimotabob
Posted: Tue May 24, 2016 12:56 am Post subject: |
I fitted Brembo goldline series to my Furano and done some research with seal kits. Brembo is good in this area as the kits come with everything.
The master cylinders have the Brembo number stamped in them and you use that to identify the seal kits.
For example i'm using the 13mm Ducati clutch master circa 916 era and i found it is the same kit that fits my Brembo brake master on my KTM.
Basically they make things easy so kit sizes are interchangeable even if the master cylinder is quite different.
Theres some tricks to rebuilding them though. Read the paperwork with the kit.
For example i done one where you put a punch inside the banjo hole to tap out the special piston and seal and then press in the new outer clip with a long drift which holds everything in place, no circlip. _________________ YB8EI |
Andy Robson
Posted: Sat Jun 18, 2016 6:48 am Post subject: |
| thanks everyone. I gave up and bought a pair of new master cylinders. Didn't want to risk a rebuild with a potential fluid leak cacking up the apintwork |
