My New V Due
Goto page Previous  1, 2
PostPosted: Tue Jul 19, 2016 11:11 pm    Post subject: Reply with quote
Yours does not have one. They're visible on the LH side...
PostPosted: Wed Jul 20, 2016 1:39 am    Post subject: Reply with quote
I quite like the carbon finish with plain silver decals. Very nice. I've thought about doing the same with the db4, don't quite have the cash to splash around just yet Crying or Very sad
V10LEE
PostPosted: Wed Jul 20, 2016 6:25 am    Post subject: Reply with quote
Ade sym wrote:
If it does have a fuel tap, where will it be situated as I cannot see it at a quick glance?
Many Thanks
Ade
Like this.
2016 Viper ACR Extreme
2010 Viper ACR
1997 Viper GTS
Too many bikes
PostPosted: Thu Jul 21, 2016 7:33 am    Post subject: Reply with quote
Not many have fuel tap though , generally 2 quick release connectors under the tank, one per fuel line.
Ade sym
PostPosted: Sat Jul 23, 2016 1:00 pm    Post subject: Reply with quote
Hi - Thanks for the reply's.
Looks like I am going to have to fit x 2 quick release connectors under the tank.
Thanks Ade
driift
PostPosted: Sat Jul 23, 2016 5:26 pm    Post subject: Reply with quote
Smart. It will look better too. Having a fuel injected model all I have is the main quick release. Have had the tank off about 5 times (plugs, wire harness, etc.) never had an issue with the quick release. Great add on by Bimota
dingbat
PostPosted: Sun Jul 24, 2016 11:59 am    Post subject: fuel tap Reply with quote
Hi my EF (!) has the cheepie screw in / out bayonet inline type tap on the main feed and which goes on to feed the side panel mounted tap but no quick release which is a bit of a pain. Both together seem to contribute to the fuelling glitches under hard acceleration sometimes when giving it a good high speed thrashing. Guessing I can get the said quick release joints from bimota as that would be a good place to start ? Looking to get a decent diameter fuel pipe and unrestricted feed to make sure the carbs are not being starved. Usual stuff, float levels etc all appear OK. Suzy RG500 used to do a similar thing I think. More of an irritation rather than a serious problem. Just now getting a chance to have a look.
driift
PostPosted: Sun Jul 24, 2016 5:48 pm    Post subject: Reply with quote
Mine has one fitting similar to this. I guess the viton o ring is important.
https://www.ebay.com/itm/351780561878
Ade sym
PostPosted: Sun Jul 24, 2016 8:08 pm    Post subject: Reply with quote
Exactly what I have purchased to fit - Ade
Weed
PostPosted: Tue Jul 26, 2016 11:01 am    Post subject: Reply with quote
The viton ORing certainly is important
JackJabba
PostPosted: Fri Jul 29, 2016 4:51 pm    Post subject: Reply with quote
Hi Ade are you know road legal?
JackJabba
Hi Ade are you now road legal?
Ade sym
PostPosted: Fri Jul 29, 2016 9:10 pm    Post subject: Reply with quote
Yes just about - Just need to get a plate made up
Ade
Page 2 of 2
