Spongebob
Posted: Fri Jun 17, 2016 1:48 pm Post subject: Rear brake light switch |
Just noticed brake light no longer operates from the rear brake. Does from front so most likely pressure switch/banjo gone u/s. Assume these common to other bikes or cars?
Does anyone have a recommendation or can share thread size on the master cylinder so I can switch for a more common type?
Oops - SB6R btw! |
Posted: Fri Jun 17, 2016 2:22 pm Post subject: |
Its a brembo unit so I'd assume a 1.00mm pitch and single banjo length pressure switch in. Best to get a stainless one _________________ Don't read everything you believe |
Bimsb6
Posted: Mon Jun 20, 2016 11:57 pm Post subject: |
Disconnect wiring from switch and short the wiring with ignition on , brake light should come on , if it does it's the switch , mine packed up years ago and was swapped out as above . |
Spongebob
Posted: Sun Jun 26, 2016 2:15 pm Post subject: |
Bimsb6 wrote: |
Done it. Was the switch. Found a spare switch off my Moto Martin. Very old but exactly the same and worked a treat! Many thanks all. If I do need a new replacement they are OEM fit to many Hinckley Triumph motorcycles. |
