DB5 won't start...do not know what to do
tenchu2x
PostPosted: Wed Jun 29, 2016 10:43 pm    Post subject: DB5 won't start...do not know what to do Reply with quote
Hi all,
i just changed the exhaust on my DB5. the original to a galasetti, its just a slip on so no major changes. afterwards i fired up the engine and gave it a ride. fine so far but i noticed than that the indicators did not work. with not working i mean that all 4 did not work and also the sign in the cockpit was not working. after that i put the bike on the stand and wanted to restart . but it did not work.
i had to push the bike back to the garage. i had the battery loaded up now but that did nothing.
when turning around the key to ignition position at first everything is normal . the cockpit (KOSO) does everything completely normal, all lights show up, nothing unusual. also the fuel pump is running up. but thats it. oh yes and the low beam and back light is shining
the ignition button does NOTHING. and yes i am pulling the clutch, i do haveneutral in and sidestand in.
what is also NOt working: indicator lights including the cockpit sign (only wotking at start up),
low /high beam switch
Horn
headlight flasher
what is working:
the kill button: pressing it makes the fuel pump start again
can it be that i do have a dead battery. i do remember that the low/high beam switch did work at first after the short ride. but than not anymore
i am thinking that given the sign that somehow all the signals from the left handelbar are not going through . all the switches on the left side do nothing, obviously including the clutch switch. this stops the ignition button on the right side to start the starting procedure.
i checked the connection under the cockpit but from eyesight did not find anything loose.
pls help guys!
cheers,
robert
