Bimotasen
Posted: Mon Jul 25, 2016 10:39 am Post subject: Paoli RSU 46, did browse the forum and Paoli manual, to lazy |
Hi All
Got some questions - to lazy to use hours for research....
Got the Paoli manual and some of the tools I guess.
Got to do the overhaul of a few of these forks....and before I disassemble and mess up big time... by trial and ERROR
1. Oil type ...SAE 10? Or any recommendations for going alternative route... both setup for road and track, knowlegde is welcome
2. Oil amount?
3. Fork seals and dust seals ...ZX9 46 mm will do the job right?
4. To my understanding the preload ajusters from ZX9 C, E is not plug and play, does plug and play items exist?
5. Fork (inner) tubes? Have a set with bend ones and a set without any at all. (thank god I have 2 sets that are straight(-ish)) Will ZX9 E 46 567 do the job? Or are they a no go? Or will other ZX ...crosser KX/WR/YZ/RM etc fit or easy-ish to shorten modify...or?
6. Fork Bushings 46x50x12 from the usual suspects fit?
7. Any models where springs will inter change? Got a pile of springs Wilbers and orig paoli ... but have no clue what is the best option ... as I remember the Wilbers is to hard and the paoli to soft
Sorry for the funny english....
Cheers Peter _________________ Bimotasen
Bimota SB6 for the Road frame 289
Bimota SB6 for the Track frame 281 - looking for a 750 engine and convert it to a SB7 replica ....Danish Classic superbike championship class 89-98 max 750 cc  |
Posted: Mon Jul 25, 2016 1:23 pm Post subject: |
Fork / dust seals are similar to ZX9R, these are common to a lot of 46mm forks
There's a thread in the SB area that covers both fork overhaul and the ZX9R fork top conversion.
There are replacement stanchions available - I think it's this but check, my Germany is very poor http://www.ebay.de/itm/BIMOTA-SB6-02-Gabelstandrohre-chrom-/111887732168?hash=item1a0d074dc8:g:2O4AAOSwGotWqRwt
Not sure about the springs, I guess that depends on the rider and what you want it for _________________ Don't read everything you believe |
Bimotasen
Posted: Mon Jul 25, 2016 5:47 pm Post subject: |
Thx Evilchicken0 got the seals confirmed then
What im fishing for is if any other than the Bimota stantions would work....
See I have a litlle spare parts shop on the side - so I dont like paying 469 Euros
If the 1 mm shorter Zx9 will work for a fractions of the prices - It also comes in funny colours like red and black -
I could offcourse just buy one and try ... but a lot less expensive if one said: "been there done that, didnt work"
Thx in advance Peter _________________ Bimotasen
Posted: Mon Jul 25, 2016 5:58 pm Post subject: |
I couldn't say I've either been there or done that
Got a spare pair of springs though, they're in the green box _________________ Don't read everything you believe |
