Throttle stuck wide open on my SB8 !!!
Seven
PostPosted: Sat Jun 21, 2008 8:59 am    Post subject: Throttle stuck wide open on my SB8 !!! Reply with quote
Out for a ride the other night, still taking it easy on the ol' girl as she's only covered 748 miles in 7 years, when all of a sudden the throttle sticks wide open and I'm unable to close it Shocked
I quickly pull in the clutch (doing about 80mph) and the engine is now bouncing off the rev limiter at 11,500rpm Shocked Shocked Shocked
Hit the kill switch and coast to a stop. Luckily a guy on an R1 stops and offers to fetch his trailer to take me home Cool What follows next is bloody hilarious Laughing
The trailer is made of wood (see pictures) and is used for carrying rubbish to the local tip. There are no fixing points to strap a bike to, so the only way to steady the Bim is to sit on the bike IN the trailer whist being towed Embarassed
The looks from the car drivers as they overtook on the dual carriageway was priceless Surprised
Respect to Ralph the R1 rider. Enjoy the pics!
Oh by the way...anyone got any ideas why the throttle won't close? Problem seems to be the 'engine' end of the throttle cable, rather than the twist grip Question Question Question Got it booked in with my local mechanic / mate so I'll keep you posted.
Seven
Admin
Site Admin
PostPosted: Sat Jun 21, 2008 1:38 pm    Post subject: Reply with quote
Can't think of anything obvious, unless some grit has got into the bush / bearing for the throttle spindle.
Keth
djt77
PostPosted: Wed Jun 25, 2008 12:04 pm    Post subject: Reply with quote
Its all good fun isn't it
Schussboelie
PostPosted: Thu Jun 26, 2008 4:54 pm    Post subject: Reply with quote
It could just be that the cable itself has corroded a bit in its housing (what do you call that metal wrapped with black plastic around those cables?).
Especially with that low mileage that could be a possibility.
Some lube oil might already fix it, try that before taking it to the shop.
Currently on a TL1000R, saving for an SB8Rs.
Not a change of heart, just a change of dress.
Admin
Site Admin
PostPosted: Fri Jun 27, 2008 12:50 pm    Post subject: Reply with quote
Generally with cables avoid using oil. Plenty of cables use a nylon liner that expands with oil causing the cable to stick.
Keith
Seven
PostPosted: Sun Jun 29, 2008 9:47 am    Post subject: Reply with quote
Bike stripped down, throttle cable has actually snapped. Sad
Quick phone around and it would appear that it is not a Suzuki part, but a Bimota one and the odds of finding a replacement are slim. The guys at Forza Italia in Silverstone were very helpful and suggested a company called Venhill Cables in Dorking, Surrey, who can custom make any cable as long as you take them the original.
Will give them a call on Monday to see if they have already made a replacement in the past...if not I'll drive down with my broken one and leave it with them. Crying or Very sad
Searching the internet it would appear that I am not alone with this problem, there have been a few issues in the past Rolling Eyes
All part of the ownership experience I suppose Wink
Seven
Schussboelie
PostPosted: Sun Jun 29, 2008 9:54 am    Post subject: Reply with quote
Bummer mate.
Can't you just send them the cable? Or are they not that far away from you?
Seven
PostPosted: Sun Jun 29, 2008 12:10 pm    Post subject: Reply with quote
Schussboelie wrote:
Bummer mate.
Not too bad...80 miles door to door...about 1.5 hours. Don't trust the postman!
Seven
Seven
PostPosted: Tue Jul 01, 2008 10:24 pm    Post subject: Reply with quote
All sorted.
Venhill Cables made me a cable whilst I waited in about 10 minutes! And only £18.......I should have bought 10 and stuck them on Ebay.....would make a killing!
My local mechanic fitted it and by the way....it is a right pig of a job as you have to remove the throttle bodies and half the bike. Whilst he was poking around he also noticed a few split vacuum hoses which were replaced as well.
Also managed to get some new brembo brake and clutch levers from Ducatisparesonline.com as the gold plating had worn off the span adjusters on mine. Very Happy
Bike is looking good and goes even better Cool
Seven
Schussboelie
PostPosted: Wed Jul 02, 2008 9:06 am    Post subject: Reply with quote
Good job!
How about a piccie?
