mm500
Posted: Fri May 06, 2016 11:07 am Post subject: My Vdue upgrades 2016 |
My Vdue 2016 upgrades:
More info is comming.... 😉 |
Posted: Fri May 06, 2016 7:47 pm Post subject: |
Can't wait to here more, I've been looking at Zeeltronics for my Vdue or for a special I'm planning..... |
mm500
Posted: Fri May 06, 2016 9:56 pm Post subject: |
another picture
driift
Posted: Sat May 07, 2016 6:22 pm Post subject: |
Carb version? |
mm500
Posted: Sat May 07, 2016 8:04 pm Post subject: |
yes this is one of the last fully sorted bikes from Piero.
this is what I did to make it work:
New modified wire harnes ( did not want to cut in the original )
Zeeltronic PDCI-24V
2 new coil + homemade CF bracket ( you can use aprilia rs250 coils)
Translogic micro dash + homemade CF bracket
new rotor from Guido
Posted: Sat May 07, 2016 9:23 pm Post subject: |
Whats the purpose of what you;ve changed to what was there in the first place> I.e. what was wrong or that you felt wasnt right.....for each bit...and how does the new bits change/improve it? |
mm500
Posted: Sat May 07, 2016 10:25 pm Post subject: |
I felt the timing and exhaust valve curve could be improved.
The PDCI-24V is fully adjustable.
For the zeeltronic to work I needed new coils and a new dash.
The Translogic dash is a hughe improvment of the old one.
I have not had time to ride it, but when I do I wil give you an update. |
Posted: Mon May 09, 2016 12:21 pm Post subject: |
Will be very interested in hearing about the riding experience . |
mm500
Posted: Mon Aug 29, 2016 7:48 am Post subject: |
Had a test drive to the local Cars and Coffe yesterday, and the bike is faster!
Stil needs the some jetting changes.
This is my current settings:
Right:
220
120
60
350
-K83
-2 turns out
Left:
220
120
60
350
-k76
-2,5 turns out
