Next Question . Steering Head Bearings
Les Caddaye
PostPosted: Thu Sep 01, 2016 2:44 am    Post subject: Next Question . Steering Head Bearings Reply with quote
Does anyone know how to get this apart. Can I just use the obligatory block of wood and Hammer??
Is there another trick?
Les
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
PostPosted: Thu Sep 01, 2016 9:26 am    Post subject: Reply with quote
Presumably the top yoke is off....and you have unwound the top cover/clamp so that all you have left is the lower yoke, lower bearing, steering head stem poking through and top bearing visible tight around the steering stem?
In which case yes......block of wood and hammer on the top steering tube.....with the frame suitably supported...you only have to get it up to the threaded part on the steering stem and then the top ball race unit should become loose....
PostPosted: Thu Sep 01, 2016 9:33 am    Post subject: Steering bearings Reply with quote
What were they thinking of?
