KB1 rear shock
Post new topic   Reply to topic    Bimota Forum Forum Index -> KB Series
Raidermoto
PostPosted: Mon Sep 12, 2016 1:01 am    Post subject: KB1 rear shock Reply with quote
Hi guys, I have frame # 395 series 2 that we restored a few years back. The owner has decided to install the rear shock that came with the bike when he bought it from the UK in 2007. The shock has a cable drive remote adjuster but the end of the cable is missing. I'm hoping someone may be able to confirm if this is the correct shock, and also have a pic of what the hand-adjuster should look like.
Kind regards,
Maurice
RaiderMoto.com
Your Portal to the World of Rare, Exotic, Unique, Custom & Vintage Motorcycles
PostPosted: Thu Sep 15, 2016 6:15 pm    Post subject: Reply with quote
Hi Maurice
My KB1 has what I believe is the original DeCarbon unit which is numbered the same as the frame. It has spring compression adjustment but that is all. Sorry not really much help but for info
Nige
Assorted Smile
Raidermoto
PostPosted: Thu Sep 15, 2016 11:28 pm    Post subject: Reply with quote
Thanks Nige, any chance you could send a pic?
My addy is mybike@raidermoto.com
Many thanks in advance
RaiderMoto.com
ct981
PostPosted: Wed Feb 08, 2017 3:08 pm    Post subject: Re KB1 Reply with quote
Indeed the original is a De carbon unit mine had the same as did my SB4
Just to note my bike is frame number 400 so were likely part of the same batch made at the time.
Mine was purchased early 1980 but obviously made in 79.
Sold at Mochech in Clapham
Carl
ct981
Carl
westfieldandy
PostPosted: Tue Jun 27, 2017 12:40 pm    Post subject: kb1 shock Reply with quote
Yes the original de carbon shock had no remote adjustment.
I have managed to spec up a k-tech unit which works well, with remote resevoir, a much better unit.
Post new topic   Reply to topic    Bimota Forum Forum Index -> KB Series All times are GMT + 1 Hour
