New DB9S !!
Goto page Previous  1, 2, 3
arsenic
PostPosted: Sun Oct 29, 2017 9:15 pm    Post subject: Reply with quote
An air filter will make things worse if not fueled properly. But you should do both at the same time imo Wink
Gavin944888
PostPosted: Mon Oct 30, 2017 12:26 pm    Post subject: Reply with quote
Hello..............here is the graph
DB9 before_after by Gavin Robertson, on Flickr
As you can see the graph shows an increase over the standard issue DB9
The standard Diavel kicks out 162 hp according to the factory... which is 129 bhp on the X Bikes dyno (obviously horses in Peterborough are bigger than in Bologna)
So...in real terms the Bimota Walbro ecu and standard DB9 settings are about 1 hp up on the red bikes down the road
More importantly is the change in graph shape ....where I use the bike.
I very rarely push above 8500- 9000 rpm being somewhat mechanically sympathetic......... coupled to scaring easily.
Final figures were achieved using a K&N filter and no cat, however, since then I have added a Arrow Titanium exhaust and reset all setting, as well as wearing tighter trousers.
I hope that this helps
regards
Gavin
Cagiva Elefant 999r engined
richtea
PostPosted: Mon Oct 30, 2017 4:58 pm    Post subject: Reply with quote
arsenic and Gavin,
Thanks both for your suggestions and info. At least now when I get a dyno run on my bike Ive got something to compare it with!
Will let you know how the fueling issues go.
cheers again
Rich
Gavin944888
PostPosted: Fri Feb 02, 2018 12:02 pm    Post subject: Reply with quote
Richtea,
How are you getting on with the DB9?
Is all good and are you enjoying Bimota ownership
Or are you still using plastic cutlery
Regards
Gavin
Gavin944888
PostPosted: Wed May 02, 2018 2:57 pm    Post subject: Reply with quote
Richtea,
That friend (and I use that term loosely) is still very serious about DB9S.
But needs one or two issues answered to put his mind at rest prior to parting with the monies......mainly with regards to the SUSPENSSSSSION
If you get a chance, please email or PM
many thanks
Gavin
richtea
PostPosted: Sun Jun 03, 2018 4:04 pm    Post subject: Reply with quote
Hi Gavin,
Sorry itís been a while since I was last on here,and sorry in such a slow response to your question!
Yes,Iím loving the DB9s, itís certainly got its querks,however,on the right roads,in the right frame of mind,when giving it 100% concentration,itís an animal!
I can only describe it as Ďrawí....
The suspension is still firm,but manageable....on a smooth track,I think it would be demon! However,if I had the dosh,I think Iíd get an ÷hlins replacement for the rear,and tailor it as best as I could to the way I ride.
The fuelling is still a bugbear,not horrendous, but just on occasion ruins what would have been a smooth progressive line around a corner!
That said, it brings a smile to my face every time I look at it, and start it up!
Not a bike to be ridden at less than 100% effort!
Page 3 of 3
