Front discs / rotors???
zokdb7
PostPosted: Sun Oct 02, 2016 9:55 am    Post subject: Front discs / rotors??? Reply with quote
Hi all,
Anyone know which bikes front rotors/discs would fit the DB7 at all?
Ducati 1098 maybe? Any advice or help would be good .
Im not paying million dollar for OEM Bimota.
Thanks in advance
PostPosted: Sun Oct 02, 2016 12:07 pm    Post subject: Reply with quote
Oem bimota is only brembo with a price hike anyway....db7 discs are 320mm....whereas ducati 1098 and after had gone to 330mm....go to motprcyclespecs.ze and find a ducati that's listed with 320mm discs...centres and offsets are the same, basically flat stainless steel brembo...
zokdb7
PostPosted: Sun Oct 02, 2016 8:52 pm    Post subject: Reply with quote
Thanks for that info
PostPosted: Sun Oct 02, 2016 11:17 pm    Post subject: Reply with quote
You could also check out Aprilia and Moto Guzzi who commonly used the same 320mm discs,,,,find one with the same start pattern rotor as on DB7....which dictates the slight offset between versions of the discs....get the right pattern of rotor and pretty much you have the right disc....
