Dyno run Bimota SB6 ????
jakob
PostPosted: Fri Apr 23, 2010 10:12 am    Post subject: Dyno run Bimota SB6 ???? Reply with quote
Hi There
I have had my Bimota SB6 on a DynoJet test bench. I my bike 114 HP on the rear wheel.
If I look in the manual, the motor schould have 156 HP in the motor.
I though the 114 HP on the rear wheel, was to little.
Is there anyone that had tried there SB6 (Standard trim) on a test bench ?
/Jakob
Seven
PostPosted: Sat Apr 24, 2010 9:00 am    Post subject: Reply with quote
Unfortunately that is about the correct rear wheel horsepower. The 156bhp is quoted at the crank and is hugely optimistic anyway.
One of the main problems is the small air box which doesn't allow the motor to breathe properly. I removed the airbox and had a Dynojet Stage 3 fitted to mine with an original SB6 race exhaust (loud!) which lifted it to around 130bhp from memory.
With the airbox gone, you could also fit a battery box in its place and upgrade to 12v conversion, instead of those stupid 2 x 6v's hidden at the front of the fairing!
Finally, remember all dynos give slightly different readings, but either way the SB6 is a very fast bike and handles superbly well. Enjoy! Very Happy
Seven
jakob
PostPosted: Sat Apr 24, 2010 10:54 am    Post subject: Reply with quote
Thank for the input. I will try to move the airbox, and find a dyno Stage 3 for my bimota
rpo83
PostPosted: Sat Apr 24, 2010 11:58 am    Post subject: Reply with quote
Hi Seven,
Doesn't the airbox support the rear of the fuel tank? Surely you would run into problems when removed?
Steve
PostPosted: Sat Apr 24, 2010 6:43 pm    Post subject: Reply with quote
My SB6 runs at 128 at the back wheel with race cans and original airbox still in tact... but great idea for the battery to help lower weight and centre of gravity... Laughing
Seven
PostPosted: Sun Apr 25, 2010 9:09 pm    Post subject: Reply with quote
rpo83 wrote:
Hi Seven,
Steve
A friend of mine who's pretty handy with sheet metal (ex Williams F1 engineer) manufactured a steel battery box which slotted into the space left by the airbox. Job done! Very Happy
Seven
jakob
PostPosted: Mon Apr 26, 2010 7:43 am    Post subject: Reply with quote
Is have looked for the original race cans. but i couldn't find the anywhere.
What kind of race cans do you have on your SB6?
If you have a picture that would be nice Smile
/Jakob
PostPosted: Mon May 17, 2010 1:02 pm    Post subject: Reply with quote
http://s109.photobucket.com/albums/n44/evilchicken0/Living%20on%20Video/?action=view&current=NoSpeedo.flv
The race cans obivously sound different but don't ad any power. You can have your originals "cored" to give a similar result but remember if you want to take it on a trackday you may need a quieter pipe. I had my race cans Camcoated to race specification (inside and out), it cuts down on heat and is a useful mod if you plan to ride any distance cos your asre dosen't get burnt.
Inside the race cans[/url]
PostPosted: Mon May 17, 2010 7:54 pm    Post subject: Reply with quote
I am working in the states at the moment so I'll post pics when I get back end of May... I have always assumed that the race cans came as stock with the original purchase rather like the Ducati sp varients?
PostPosted: Tue May 18, 2010 11:07 am    Post subject: Re: Dyno run Bimota SB6 ???? Reply with quote
jakob wrote:
Hi There
/Jakob
Had my first SB6 on a dyno, it made high 120's with a slipping clutch Shocked
the stock GSXR made more than that.
My 6R is putting out a shade under 140 rwhp
so I'm guessing it's not your pipes that are causing the problem as all of mine had/have standard pipes Wink
PostPosted: Tue May 18, 2010 11:12 am    Post subject: Reply with quote
Are you sure you'll be back at the end of May.......
With the UK airports being closed more than open at the moment due to volcanic ash, you may be having a long "channel night" in the Azores Laughing
PostPosted: Tue May 18, 2010 12:51 pm    Post subject: Re: Dyno run Bimota SB6 ???? Reply with quote
Yes it's down to the smaller airbox on the 6, and the standard K+N 2in one pod filters don't fit the tail unit. I had a set of Acropavic down pipes for a GSX-R and the only disernable difference is the pipe diameter where two downpipes join into (the 2 in the 4-2-1) which was larger.
Bimota
Acro
PostPosted: Tue May 18, 2010 2:12 pm    Post subject: Reply with quote
I think I've read about a mod for the SB6 airbox which releases a few more gee gee's.
I'll have a look to see if I can find it Wink
PostPosted: Tue May 18, 2010 5:24 pm    Post subject: Reply with quote
You mean like drilling holes in the side near the shock and removing the wire gauze from the other. Then cutting down a K+N flat filter to fit in place of the original & making sure the air pipe from the fairing feeds the airbox ????
Nope not heard that one Wink
PostPosted: Tue May 18, 2010 5:45 pm    Post subject: Reply with quote
Laughing
Nope, somthing a bit more shophisticated than the usual bodge Wink
While we'er on the subject of air filters, anyone know which is the best K & N for the SB6 airbox?
