Battery for DB1 - Orientation?
PaulDB2
PostPosted: Wed Mar 08, 2017 1:38 pm    Post subject: Battery for DB1 - Orientation? Reply with quote
Hoping some kind soul can help out here. Just about to order a battery for my DB1 and realised I am not sure which way round the battery terminals need to be. (The DB1 did not have a battery when I imported it - transit rules).
The battery type I believe is a YB14L, but is it an A2 or a B2?
Do the terminals on the battery sit towards the front of the bike or towards the rear when mounted in it's frame?
The positive terminals in my wiring harness seem to indicate the positive terminal on the battery should be on the left side (as sat on the bike).
Quadrasuarass
PostPosted: Wed Mar 08, 2017 8:48 pm    Post subject: Reply with quote
Will have a look for pics this evening from my resto project. Meanwhile heave you considered a Lithium Ion Battery. I have been recommended Motobat by a knowledgeable electrical engineer who is fully conversant with the foibles of Ducatis and there brethren. 1/2 the size and 1/3 the weight with a higher cold cranking capacity. I've also moded the battery box to suit this which opens up space under it to let more air in over the back cylinder head.
Quadrasuarass
PaulDB2
PostPosted: Wed Mar 08, 2017 9:24 pm    Post subject: Reply with quote
Thanks Quadrasuarass, thanks for looking. Not really considered lithium ion battery, but I will look at them also, not as expensive as I thought previously. Don't really want to start hacking the battery box about, but getting more air around the motor is a plus.
Quadrasuarass
PostPosted: Thu Mar 09, 2017 6:23 am    Post subject: Reply with quote
First shot is original battery, positive terminals to the front, positive on the left when sitting on the bike as you noted.
Second shot is comparison with Ultrabat - 3 module (not Motobat as previously mentioned)
3rd Shot is normal Ultrabat Install
4th and 5th shots are my mock up of ultrabat install from the side and front. You can see the extra opening available below the battery to let air over the rear cylinder head
Battery box was lightly modified with a hole saw to get air over the LiPo battery and tin snips/vicegrips to create a landing for the smaller battery to sit on, then all off to the powder coater for a fresh coat of paint.
Nigel
PostPosted: Thu Mar 09, 2017 9:39 am    Post subject: Reply with quote
Lovely work....But just what are those valve covers made of???? They look like 1950's Bakerlite like my Grandads Old Roberts Radio???
PaulDB2
PostPosted: Thu Mar 09, 2017 11:18 am    Post subject: Reply with quote
Thanks Quadrasuarass, that helps a great deal.
Is that steering damper original, mine is circular in section?
Are the valve covers magnesium?
Quadrasuarass
PostPosted: Thu Mar 09, 2017 9:41 pm    Post subject: Reply with quote
Valve covers are standard that have been pimped up a bit with some flash powder coating. I believe that the steering damper is standard.
Bike was really tatty when I got it; project name is DBling1 which gives you an idea of where this is heading.
Nigel
PostPosted: Fri Mar 10, 2017 1:21 am    Post subject: Reply with quote
Nigel
Different damper body and clamp from that on my DB1....but heck...twud be whatever they could get hold of I imagine...as per the norm...
Quadrasuarass
PostPosted: Fri Mar 10, 2017 3:44 am    Post subject: Reply with quote
Having said it was on the bike when I got it the damper also has a non standard bracket to hold it away from the frame and let it work properly so maybe mine is not original. No markings on it to say what it is but it works fine
PostPosted: Fri Mar 10, 2017 6:54 am    Post subject: Reply with quote
None of the early db series. 1, 2 or 4 have markings on the dampers to say who made them...so maybe...
