sb6r throttle cables what are they ?
gary sb6r
PostPosted: Mon Apr 17, 2017 5:22 pm    Post subject: sb6r throttle cables what are they ? Reply with quote
Push throttle cable has come apart on my SB6R
Pull cable looks a bit tired as well.
I was hopefull that a standard set of cables from suzuki WP would fit
but unfortunately not.
Anyone know what and where I can get these cables from I have tried
Venhill and they can only make copies from the original (4 weeks lead time)
any help gratefully accepted
Gary
G Smith.
Current rides, SP2, CBX special, ZX12R, ZX7R, GPZ1100a2 , SB6R, 1200 daytona
PostPosted: Mon Apr 17, 2017 6:25 pm    Post subject: Reply with quote
I'd have said Venhill
Could you get their repair kits and replace the cores ?
Admin
Site Admin
PostPosted: Mon Apr 17, 2017 11:27 pm    Post subject: Reply with quote
Venhill sell a kit for making your own cables. You will need a powerful soldering iron, or a solder pot.
Not cheap, but then nor are one off cables (a choke cable for my Dieci came to about 45 once VAT and postage was included).
Katy
PostPosted: Tue Apr 18, 2017 9:28 am    Post subject: Reply with quote
You can use screw / bolt on nipples.
I use bolt on with exup cables
PostPosted: Tue Apr 18, 2017 9:35 am    Post subject: SB6R cables Reply with quote
Making your own cables is not difficult, but as Admin says, you need a solder pot. A soldering iron, doesn't do the job nearly effectively enough. If you've gone to the expense of a solder pot, you also want a birds nest tool to prepare the end of the cables to go into the nipple. There won't be much change out of 250, which militates in favour of getting Venhill to make them up for you, unless you've a number of bikes over which to defray the cost.
Admin
Site Admin
PostPosted: Tue Apr 18, 2017 12:46 pm    Post subject: Reply with quote
Hiya
I bought a cheap solder pot, for just over 10. Seems to work fine although it holds more solder than you would think
I haven't got a bird cage tool. Just splay the ends out once the nipple is on the cable then solder. I have used a soldering iron, but it is an 80w one and barely adequate for the job
Katy
PostPosted: Tue Apr 18, 2017 2:38 pm    Post subject: SB6R cables Reply with quote
Looks like I've been mugged again Sad
But I would recommend the bird cage tool - just do me a favour & keep it to yourself, if you manage to pick one up for ten bob Crying or Very sad
PostPosted: Tue Apr 18, 2017 3:20 pm    Post subject: Reply with quote
Like everything you can buy the cheapest of the cheap or the Rolex version......
PostPosted: Tue Apr 18, 2017 4:12 pm    Post subject: SB6R cables Reply with quote
True enough Stockcar and my solder pot keeps time like no other Laughing
Admin
Site Admin
PostPosted: Wed Apr 19, 2017 12:50 am    Post subject: Reply with quote
I have no doubt that there are better solder pots, but for occasional use this one is fine.
Bird caging tool is tempting, but at 100 they are not cheap
Katy
PostPosted: Wed Apr 19, 2017 9:10 pm    Post subject: Reply with quote
I've never heard of a bird caging tool so I googled it
https://www.youtube.com/watch?v=PV3XLAG3jx8
It's a tool for flaring out the end of the cable. You learn something every day.
I use one of those mini gas powered soldering torches for most things on the bike so I don't have problems heating up the cable ends when making a cable. I've made a heap of accelerator and clutch cables and never had a failure even without the mysterious bird caging tool.
PostPosted: Thu Apr 20, 2017 1:00 pm    Post subject: Reply with quote
I wondered if the throttle cable would benefit from a 90 deg bend at the carb end ???
gary sb6r
PostPosted: Tue Apr 25, 2017 9:16 pm    Post subject: Reply with quote
looks like making my own cable is the way ahead
i like the idea of the bend at the carb end to save the kinked cable
Took the old girl out today and put a massive smile on my face.
Just love the sound of that beast
Even better news I got a fuel float level switch and even better it looks like it might fit.
I will let you know how I get on once the sun hides and the rain comes back
cheers for all your help
G Smith.
PostPosted: Tue Apr 25, 2017 11:31 pm    Post subject: Reply with quote
I got on the 6 at the weekend, about 4.5 hours ... I'm rusty and a bit scared but nice sitting at 70 ☺ on the A1 where the engine goes quiet
Still got jobs to do and the rear number plate mudgard wanted to fall off !!!
gary sb6r
PostPosted: Sat Mar 17, 2018 8:39 pm    Post subject: Reply with quote
Got venhil to custom make me some cables for the SB6R from my template
They should have the specs now should anyone need a set
Should save someone some hassle
G Smith.
